someone have a bios hp mini 210 for spi flash with ezp2013
Need Bios hp mini 210
Re: Need Bios hp mini 210
this may help you
Attached Files -
try this bro, good luckAttached FilesComment
quanta NM6 should be the platform. From a chinese site:Attached FilesComment
do you have DC bench power supply?
http://www.berniaga.com/ATTEN+APS300...A-17819410.htm
on many case for me if stuck on 0.8A-0.9A look like bios problem
some times you should change the IC and reprograme itComment
the problem occurs when the update bios, before bios update laptop normal, after update no display, because bios update when the process is slow and that had a laptop to turn it off, then turn it on again the laptop no display, heheeeHidup yang benar2 membosankan.. hek that bak mita pengComment
Hi
The problem an't the bios ..if the last file uploaded didn't work and i just check that file from the newest update from hp for your exact model they are exact no different.... So do you have external display? did you force it by unplugging internal cable..use flash light do you see any data on screen if yes then back light is out ...check display switch ....voltage on pin one of inverter ? whats is it .
Techman1025Comment
1. Download:
http://ftp.hp.com/pub/softpaq/sp60501-61000/sp60935.exe
2. Unpack (7zip)
3. Use phoenix tool 2.50 to open (decrypts), you got the bin file.
4. Use HP Dmi tools to insert sn and other numbers if needed.Attached FilesComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... - Loading...
