DV6721 BIOS dump
  • rievax_60
    • May 2012
    • 897
    • australia
    DV6721 BIOS dump
    Does anyone have a BIOS dump for a HP DV6721 TX?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: DV6721 BIOS dump
    Or anything that might work ok.
    • rievax_60
      • May 2012
      • 897
      • australia
      After some searching I found that it's easy to get the BIOS BIN from the HP BIOS update download, if I have done it right, nothing has changed. The EC just sits there reading the EEPROM and doing nothing else.
      Originally, ALWP 5v and 3.3v were missing. Replacing PU10 on page42 restored these rails.
      ACIN_1, pin86 on the EC page48 is high.
      Can someone suggest any other important things to check?
      • rievax_60
        • May 2012
        • 897
        • australia
        I replaced the EC with one I purchased on ebay. It was a good surprise the see the laptop then work properly.
        I had previously rewrote the BIOS EEPROM with a cheap EN25T80 Programmer on ebay.
        Although I now now this wasn't necessary, the rewrite must have been successful anyway.
        I found by searching that there was never a need to ask for a BIOS dump. The BIN is easily extracted from one of the official HP BIOS update downloads.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          glad to hear it working... usually rewrite cannot be done so easily
          Im Back... sort of...
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
