can someone split the L850 bios file for me ?
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: can someone split the L850 bios file for me ?
    well usually they are some problem with the transcoder for the image , and IC near the LVDS , chek if you got the correct signal coming from it , it no signal from it , replace it
    • jcarreira
      • 4
      • portugal
      hi, but in that case i must have signal in external video?
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        well if you dont have on internal pratically sure you wont have on external , since this transcodes also connect VGA
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          but does IC work as blocks , electronics somethimes are something incredible and somethimes something horrorific !
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
            07-23-2023, 07:39 AM
          • MrBojangles
            Z690P WIFI D4 need to split BIOS file
            by MrBojangles
            This motherboard has the unfortunate thing where it splits the Bios file into one 16 Mb part and 8 Mb backup and I still don't know how to perform the split.
            I don't know if the procedure is specific to this board or if there is a general rule on how to do this. I would appreciate if someone could do it for me. Thanks ...
            08-18-2025, 03:00 AM
