Z690P WIFI D4 need to split BIOS file
  • MrBojangles
    • Jul 2024
    • 50
    • Sweden
    This motherboard has the unfortunate thing where it splits the Bios file into one 16 Mb part and 8 Mb backup and I still don't know how to perform the split.
    I don't know if the procedure is specific to this board or if there is a general rule on how to do this. I would appreciate if someone could do it for me. Thanks
    • 22236
    here
    • MrBojangles
      • Jul 2024
      • 50
      • Sweden
      Originally posted by SMDFlea
      here
      Thanks you're the boss!
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
