hp dv6 bios
  • solomost
    • Sep 2021
    • 40
    • agadir
    Re: hp dv6 bios
    hi
    my friend i need dump for hp pavillion dv6-1123 sf
    thank you
    • peste
      • 13639
      • ROMANIA
      Re: hp dv6 bios
      Originally posted by solomost
      hi
      thank you
      post the bios backup
      • solomost
        • Sep 2021
        • 40
        • agadir
        Re: hp dv6 bios
        thank you
        • peste
          • 13639
          • ROMANIA
          Re: hp dv6 bios
          thank you
          try .. if it doesn't work, post the motherboard model ..
          • solomost
            • Sep 2021
            • 40
            • agadir
            Re: hp dv6 bios
            thahk you very much
            • hs.leomessi@gmail.com
              • Feb 2022
              • 10
              • iran
              #26
              Re: hp dv6 bios
              hp dv6-3145dx DA0LX8MB6D1 rev: D
              BIOS needed
              • peste
                • 13639
                • ROMANIA
                #27
                Re: hp dv6 bios
                BIOS needed
                bos extracted from the HP site update
                • almussafer
                  • Jun 2019
                  • 86
                  • Iraq
                  #28
                  Try this file ok100%
                  • spmetroil
                    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                    by spmetroil
                    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                    I have a CH341A programmer and I already attempted the following steps:
                    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                    08-19-2025, 09:23 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • haitham sharabati
                    by haitham sharabati
                    Hello engineers 😀,
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    💀 Problem:😅
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • bestrafer
                    Lenovo L460 LAN issue after BIOS dump flash
                    by bestrafer
                    Hello everyone.
                    I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
                    BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
                    But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
                    Could someone point on a direction...
                    01-31-2023, 01:14 PM
