hp dv6 bios
  • solomost
    • Sep 2021
    • 39
    • agadir
    Re: hp dv6 bios
    hi
    my friend i need dump for hp pavillion dv6-1123 sf
    thank you
    • peste
      • Dec 2016
      • 12557
      • ROMANIA
      Re: hp dv6 bios
      Originally posted by solomost
      hi
      thank you
      post the bios backup
      • solomost
        • Sep 2021
        • 39
        • agadir
        Re: hp dv6 bios
        thank you
        • peste
          • Dec 2016
          • 12557
          • ROMANIA
          Re: hp dv6 bios
          thank you
          try .. if it doesn't work, post the motherboard model ..
          • solomost
            • Sep 2021
            • 39
            • agadir
            Re: hp dv6 bios
            thahk you very much
            • hs.leomessi@gmail.com
              • Feb 2022
              • 9
              • iran
              #26
              Re: hp dv6 bios
              hp dv6-3145dx DA0LX8MB6D1 rev: D
              BIOS needed
              • peste
                • Dec 2016
                • 12557
                • ROMANIA
                #27
                Re: hp dv6 bios
                BIOS needed
                bos extracted from the HP site update
                • almussafer
                  • Jun 2019
                  • 70
                  • Iraq
                  #28
                  Try this file ok100%
                  • bestrafer
                    Lenovo L460 LAN issue after BIOS dump flash
                    by bestrafer
                    Hello everyone.
                    I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
                    BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
                    But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
                    Could someone point on a direction...
                    01-31-2023, 01:14 PM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • AkaBukai
                    Is it okay to flash stock bios onto the motherboard's BIOS?
                    by AkaBukai
                    Hi there,
                    I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                    The little LED on the power button is flashing slowly and nothing happen.
                    This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                    So I decided to flash the BIOS using a cheap programmer.
                    And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                    I also...
                    12-19-2024, 12:15 PM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
