hp dv6 bios
  • solomost
    • Sep 2021
    • 39
    • agadir
    Re: hp dv6 bios
    hi
    my friend i need dump for hp pavillion dv6-1123 sf
    thank you
    • peste
      • Dec 2016
      • 12734
      • ROMANIA
      Re: hp dv6 bios
      Originally posted by solomost
      hi
      thank you
      post the bios backup
      • solomost
        • Sep 2021
        • 39
        • agadir
        Re: hp dv6 bios
        thank you
        • peste
          • Dec 2016
          • 12734
          • ROMANIA
          Re: hp dv6 bios
          thank you
          try .. if it doesn't work, post the motherboard model ..
          • solomost
            • Sep 2021
            • 39
            • agadir
            Re: hp dv6 bios
            thahk you very much
            • hs.leomessi@gmail.com
              • Feb 2022
              • 9
              • iran
              #26
              Re: hp dv6 bios
              hp dv6-3145dx DA0LX8MB6D1 rev: D
              BIOS needed
              • peste
                • Dec 2016
                • 12734
                • ROMANIA
                #27
                Re: hp dv6 bios
                BIOS needed
                bos extracted from the HP site update
                • almussafer
                  • Jun 2019
                  • 71
                  • Iraq
                  #28
                  Try this file ok100%
                  • bestrafer
                    Lenovo L460 LAN issue after BIOS dump flash
                    by bestrafer
                    Hello everyone.
                    I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
                    BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
                    But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
                    Could someone point on a direction...
                    01-31-2023, 01:14 PM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • MDSI
                    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                    by MDSI
                    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                    Details:
                    Model : HP OMEN 17-an012nf
                    Motherboard Part Number : DAG3BAMBAF0 REV : F
                    Serial Number (S/N) : 5CD7280D51
                    BIOS chip : Winbond W25Q64VSIQ
                    Programmer : EZP2023+
                    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                    I already...
                    Yesterday, 07:11 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • AkaBukai
                    Is it okay to flash stock bios onto the motherboard's BIOS?
                    by AkaBukai
                    Hi there,
                    I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                    The little LED on the power button is flashing slowly and nothing happen.
                    This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                    So I decided to flash the BIOS using a cheap programmer.
                    And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                    I also...
                    12-19-2024, 12:15 PM
