Panasonic FZ-G1 MK5 bios
  • zevar
    • Nov 2025
    • 6
    • Belarus
    I have installed a LAN port in my Panasonic FZ-G1 instead of a barcode scanner, but it is not defined in Bios and it is not seen by Windows 10 Device Manager, does anyone know how to make it work, need to edit Bios, can someone help me?
    • 22293
    post the laptop serial number ,bios backup and the full model number
    • zevar
      • Nov 2025
      • 6
      • Belarus
      Panasonic FZ-G1 MK5
      Model No: FZ-G1W3301VH
      Serial No: 1ATSC63517
        SMDFlea commented
        Editing a comment
        posts moved to a new thread topic as yours is a MK5 not MK4.
      • 22293
      You only posted the 8MB bios region. Try this bios, if you can`t flash it back with afuwin you`ll need to use an SPI programmer and post the whole bios backup.
      • zevar
        • Nov 2025
        • 6
        • Belarus
        I'll try reading the Bios chip with a programmer. Can anyone tell me where it is on the MK5 board?
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
        • aa10aa10
          Panasonic Toughbook CF-33 mk1 BIOS repair
          by aa10aa10
          Good day,
          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
          01-21-2025, 06:13 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
