Dell XPS 13 7390 bios
This topic has been answered.
  • fabyband94
    • Sep 2019
    • 9
    • italia
    Good evening, I have a Dell 7390, the power LED turns on for 3 seconds then goes off. I tried another bios found on this forum, it turns on but the display starts to appear after 3 minutes.
    cpu i7
    service tag FFYPFB3
    edp35 la-h931p rev:1 (A00)
    I attach the original bios.
    I thank anyone who can help me.
    • fabyband94
      • Sep 2019
      • 9
      • italia
      With this bios found online, the notebook turns on, but does not see the memory. Furthermore, the service tag should be corrected, is it important?
      • LBTT1121
        • Nov 2024
        • 1185
        • Việt Nam
        cpu i7
        service tag FFYPFB3
        back up bios no choose OTP , or try https://www.badcaps.net/forum/troubl...61#post3754861
        • quarka35
          • Oct 2025
          • 13
          • FRANCE
          Dear fabyband94,
          Please find attached my working BIOS with NVME support.
          I believe you’re experiencing the same issue as I did.
          Your BIOS dump doesn’t contain only the BIOS itself; it also includes your laptop’s configuration data.
          I manually edited my configuration to correct the NVMe settings in a clean image.
          By default, the system boots, but some voltage and PCIe parameters aren’t configured correctly. I went through each setting one by one to ensure they matched my laptop’s original configuration.
          You could try using my fixed firmware, where I corrected the NVMe configuration. My NVME drive is now properly detected, and I’m fairly certain it would work for you as well. The service tag doesn’t seem to be particularly important in this case.
          For information, I fix many thinks like voltage on some GPIO.
          If you open your file using "Intel CSME System Tools v14.0.11-r1," you’ll be able to see your SATA and PCIe configuration details.
          My working configuration for nvme
          ​Best regards,​
          • fabyband94
            • Sep 2019
            • 9
            • italia
            Thank you so much. You solved my problem, everything works perfectly now. Thanks again.
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Loli Popu
              DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
              by Loli Popu
              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
              12-13-2024, 08:29 AM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • wwbielsko
              Dell latitude 5320 corrupted bios repair
              by wwbielsko
              I got corrupted bios bin file, which way is correct to repair.
              File puts errors on Me Analyzer and cannot open in FIT.
              To open in FIT I made:
              1. Extract MFS and EFS using MEAnalyzer from other bios file with the same parameters
              2. put it in HxD to my file
              3. MEAnalyzer shows 1 error after that
              4. file opens in FIT
              and:
              A:
              1. extract current dell bios on website
              2. put System BIOS with BiosGuard v1.30.0.bin using FIT
              3. MEAnalyzer OK no errors
              (this version shows only logo at bootup - freezeing)...
              04-23-2024, 06:16 PM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
