Dell XPS 13 7390 bios
This topic has been answered.
  • quarka35
    • Oct 2025
    • 12
    • FRANCE
    I have my bios corrupted.
    Could you help me to fix it ?
    Model: Dell XPS 13 7390
    Service code: DC2MM13
    Please find attached corrupted bios.
    I need 32MB version because my flash is Winbond W25Q256JV
    Thank you so much.
  • Answer selected by quarka35 at 11-03-2025, 06:40 AM.
    SMDFlea
    • 21986
    Originally posted by quarka35
    ME section seems to be clean thank you. ME Analyser detect issue Note: Multiple (2) Intel Flash Descriptors detected! and UEFITool.exe have trouble to open it FfsParser::parse: not a single Volume Top File is found, the image may be corrupted
    I try it and keyboard is light during 3 seconds then shutdown, this fix is corrupted.
    How to fix to have only one volume ?
    Thank you for you help.
    Try this bios.
    • peste
      • Dec 2016
      • 13661
      • ROMANIA
      Thank you so much.
      post S/T full name and model, motherboard model, ,etc.
      • quarka35
        • Oct 2025
        • 12
        • FRANCE
        Thank you for your replied, but is not 2 in 1 model and not the same service code.
        I have my bios corrupted and locked.
        Could you help me to fix it at least and unlock it if you can ?
        DP/N: 0K2NCP
        Compal P/N : PK1320C3A17
        Lite-on P/N: SG-88600-2FA
        Lite-on S/N: 20031300086
        Model No: SN7270BL
        What additional information do you need?
        Thank you so much.
        • pdblues2231
          • Jun 2022
          • 53
          hi, try this...
          • quarka35
            • Oct 2025
            • 12
            • FRANCE
            Originally posted by pdblues2231
            hi, try this...
            Thank you for your reply. However, my flash memory is 32 MB, while your file is only 16 MB. Are these just the files extracted from the Dell package? I don’t quite understand. The binary file contains data beyond 16 MB. Are you sure it will work ? Is it sufficient to have only the System BIOS information? Also, how can I create a complete binary image from the .rcv or .exe file provided by Dell?
            Best regards,
            • pdblues2231
              • Jun 2022
              • 53
              hi, there
              very strange oem files are 16mb.. I replaced the compressed filed with a new one from dell. Try this one but its still 16mb... I just flashed the same laptop here and it worked fine.
              Is the file you posted the dumped one from the actual chip??
              • quarka35
                • Oct 2025
                • 12
                • FRANCE
                hi, there
                Yes oem file are 16MB but full dump is 32MB I think there are not only bios on the memory.
                It is a XPS 13 7390 (no touch screen, no 2 in 1) and not a latitude.
                In this topic other pepole have 32MB binary and they can be openned with UEFITool NE
                Click image for larger version  Name:	image.png Views:	0 Size:	81.1 KB ID:	3754855
                But my corrupted file I have some issue
                Click image for larger version  Name:	image.png Views:	0 Size:	68.6 KB ID:	3754857
                If someone has a full 32 MB dump of the Dell XPS 13 7390, I might be able to fix my laptop. I have already tried using the files XPS 7390 32m.bin and W25Q256FV@WSON8 8X6_20230608_144945 Unlocked.bin, but the laptop remains completely off with no power LED.
                With my corrupted binary, the power LED turns white and the keyboard backlight comes on for about 2–3 seconds before shutting down.
                My computer is functional (before); I just want to unlock it. Before reflashing, I dumped the BIOS several times and compared the files to ensure they matched. I then erased and attempted to reflash, but it still doesn’t work. I suspect there’s an issue with my dump because the file cannot be opened with UEFITool, which strongly suggests the dump is corrupted.
                • LBTT1121
                  • Nov 2024
                  • 1068
                  • Việt Nam
                  try and feedback
                  • pdblues2231
                    • Jun 2022
                    • 53
                    hi there..
                    quite a busy day here...bit of confusion.. try this one its 32mb, a cleaned copy of your bios... should work... please let us know...
                    • quarka35
                      • Oct 2025
                      • 12
                      • FRANCE
                      Originally posted by LBTT1121
                      try and feedback
                      Dear LBTT1121,
                      You save my laptop, it is works.
                      Could you share me how do you proceed to fix my corrupted file ?
                      Thank you so much !!
                      • LBTT1121
                        • Nov 2024
                        • 1068
                        • Việt Nam
                        Dear LBTT1121,
                        try https://www.badcaps.net/forum/troubl...rces-and-tools
                        • quarka35
                          • Oct 2025
                          • 12
                          • FRANCE
                          Do you know why my nvme is not detected ? is a standard M2 external nvme I try 2 of them and is not detected ?
                          Laptop boot many time with nmve not detected and after power led is down nothing happen like dead.
                          If I reflash binary it works again. Memory seems to be modified .
                          Thank you.
                          • quarka35
                            • Oct 2025
                            • 12
                            • FRANCE
                            Thank you.
                            I have a Dell XPS 13 7390 (non–2-in-1 model). The BIOS currently shows version 1.4, which seems to belong to the XPS 13 7390 2-in-1 model. However, for my system, the latest correct BIOS version should be 1.29.
                            Can someone help me replace the current BIOS with version 1.29 instead of 1.4?
                            Thank you.
                              • 21986
                              Thank you.
                              Your posts have been moved from the 2 in 1 topic to a new thread. It seems your posts were merged by mistake with the 2 in 1 topic .
                              • quarka35
                                • Oct 2025
                                • 12
                                • FRANCE
                                Thank you it seems better to have a specific topic for this specific model.
                                I downgrade my bios to V1.29 with bios updater and USB key but its changes nothing my nvme is not detected. Do you have any Idea ? The fix to repair my corrupted binary maybe is not the right due to wrong model ?
                                Thank you for help
                                • quarka35
                                  • Oct 2025
                                  • 12
                                  • FRANCE
                                  Thank you for help
                                  I Think the issue is due to the very old ME region.
                                  Do you have idea how to fix my corrupted ME region ? to be able to use my nvme
                                  Thank you
                                  • quarka35
                                    • Oct 2025
                                    • 12
                                    • FRANCE
                                    hi there..
                                      • 21986
                                      Your backup at post 1 has two 16MB bios images, one after the other, that`s why there are two flash descriptors.
                                        • 21986
                                        Try this bios.
                                        • quarka35
                                          • Oct 2025
                                          • 12
                                          • FRANCE
                                          Try this bios.
                                          It is works.
                                          Memory is not only BIOS we need to keep configuration etc. NVME was not configured correctly, if I adapt configuration of default one It works too.
                                          Thank you, for your help.
                                          Best regards.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Loli Popu
                                            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                            by Loli Popu
                                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                            12-13-2024, 08:29 AM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • wwbielsko
                                            Dell latitude 5320 corrupted bios repair
                                            by wwbielsko
                                            I got corrupted bios bin file, which way is correct to repair.
                                            File puts errors on Me Analyzer and cannot open in FIT.
                                            To open in FIT I made:
                                            1. Extract MFS and EFS using MEAnalyzer from other bios file with the same parameters
                                            2. put it in HxD to my file
                                            3. MEAnalyzer shows 1 error after that
                                            4. file opens in FIT
                                            and:
                                            A:
                                            1. extract current dell bios on website
                                            2. put System BIOS with BiosGuard v1.30.0.bin using FIT
                                            3. MEAnalyzer OK no errors
                                            (this version shows only logo at bootup - freezeing)...
                                            04-23-2024, 06:16 PM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
