Request BIOS Acer SF314-44 , NB2632_MB_V4
  • phucvinh171085
    • Mar 2018
    • 3
    • abc
    PLEASE HELP ME BIOS Acer SF314-44-R2U3 , NB2632_MB_V4 , THANK !
  • hoaca388
    Badcaps
    • Jan 2022
    • 12329
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • phucvinh171085
      • Mar 2018
      • 3
      • abc
      S/N: NXK0WSV001227022BC2N00
      My laptop has power but no screen display, I need a 16MB bios file
        SMDFlea commented
        Editing a comment
    • Fryderyk Nietzshe
      • Nov 2024
      • 3
      • Polska
      Hi All. I do have an exact same motherboard on bench . I do suspect the bios, as I cannot see any other issue on the PCB. I have power and there is an initial fan spin and i do take those as good signs as not to be a dead CPU - no shorts on VRMs also a good sign. I do attach a bios dump from my machine. Hope someone will be able to determine if this is the issue. I tried to get official clean bios, but the fd's from Acer are beyond my knowledge in this department.
      Also as per additional info:
      S/N: NXK0WEP002227021C52N00
      Thanks in advance
        • 21874
        Thanks in advance
        Attached are 3 different bios versions extracted from the bios update. Don`t know which yours is so try all 3 ,it`s dependent on the power delivery hardware on the motherboard.
        DMI
        EA7000 - EA714F
        EAA000 - EAA03F
        Also attached are 3 macro scripts to copy the DMI from your backup to each bios, instructions for that are below -
        Code:
        This will only work if you have made a good backup !!!!!!
        1. Install Tiny Hexer hex editor -> https://www.softpedia.com/get/Others/Miscellaneous/tiny-hexer.shtml
        2. Make a new folder on your C: drive called DOLPHIN
        3. Move or copy contents of extracted scripts.zip to DOLPHIN folder
        4. Move or copy your bios backup and the 3 new bios to the DOLPHIN folder
        5. Rename your backup bios to flipper.bin
        6. Run each of the scripts one at a time, after each script has run close Tiny Hexer before moving onto the next one
        Please leave feedback if it has worked for you, and also consider making a donation to badcaps or a dolphin sanctuary.
        • Fryderyk Nietzshe
          • Nov 2024
          • 3
          • Polska
          [/CODE]
          Thank You!
          I am still not on the end of the work, but I do have a new behavior from the laptop. With bios files that you provided laptop after start now powers on the backlight - resets four times and goes down. For my surprise with all off them. For in depth comparison and to eradicate potential of issues with the original DMI sectors i did also checked with blank files. So my assumption there is still some physical issue with the board itself. The usual check with caps-lock does suggest we are still a no-post. I will need to search for a boardview as the only suspicious part with unusual heat signature is BQ25700 section of the board. Nonetheless I do appreciate the effort. Thanks
            • 21874
            Thank You!
            The boardview/schematic doesn`t seem to be available at the moment but i may be wrong. You can post a request for them in the schematics forum https://www.badcaps.net/forum/troubl...-requests-only
            What is the EC chip part number, can you make a backup
            • Fryderyk Nietzshe
              • Nov 2024
              • 3
              • Polska
              Unfortunately i will not be able to get the FW fro EC. It is ITE IT5571VG-128 a BGA chip. I do not have any programmer adaper for this form-factor and without schematic - i will post request as you suggested i do not have any reference points to try.
                • 21874
                You would need an EC programmer such as a SVOD4 or Vertyanov SUCCESSOR to make a backup from the keyboard connector
                This is a different motherboard
                NB2665 KB_pins=28 LEFT UP 1MM PD0=28 PD1=27 PD2=26 PD3=25 PD4=24 PD5=23 PD6=22 PD7=21 BUSY=19 STB=10 AFD=9 INIT=8 SLIN=7 KSI4=6 KSI5=5
                • ebyte64
                  Bios request for Acer P214-52-58CH
                  by ebyte64
                  Good day.
                  I would like to request a bios for the following laptop?
                  Model: Acer P214-52-58CH
                  Model No: N19Q7
                  S/N: NXVLHE0H11204BA27600
                  SNID: 11201936276
                  Symptoms: Laptop powers on but no picture on screen.
                  I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
                  09-25-2024, 05:59 AM
                • Wg188
                  ACER Veriton Z4660G AIO bios help
                  by Wg188
                  I have an Acer veriton Z4660G all in one pc,
                  Model: Z4660G-I5850H1 (VZ4660G_W)
                  Need bios dump and schematic would save my life !
                  to make a long story short I bought this all in one used
                  with a broken lcd, with the objective of making a custom desktop out of it
                  ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                  06-17-2023, 02:20 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • justice171
                  Acer AL14-31P-C8KV BIOS Request
                  by justice171
                  Hello Badcaps Team,
                  I am working on an Acer AL14-31P-C8KV laptop (S/N: NXKS8EA0013490A9C74500) with board number T140AN Rev 3.0A.
                  I received this unit for repair, but I am uncertain if the current BIOS is correct. There are clear signs of previous work – I noticed flux residue around the BIOS chip, which suggests the BIOS may have been tampered with or reprogrammed before. Because of this, I am not confident that the backup BIN I have is the original dump or if it belongs to this exact machine.
                  Could you please assist me with:
                  • A clean BIOS BIN for this
                  09-03-2025, 01:50 AM
