BIOS FOR DAY11AMB6E0 REV E Model Hp hp pavilion 15 - p213nq
  • hicham07
    Programmer
    • Jun 2016
    • 10
    MOTHERBAORD = DAY11AMB6E0 REV E
    bios chip = GD25B64BSIG
    S/N 5CD5253TW5
  • hicham07
    Programmer
    • Jun 2016
    • 10
    Any idea guys?
      • 22283
      Originally posted by hicham07
      Any idea guys?
      If you explain what the problem is we might get a few ideas. If you have a backup post it.
      • hicham07
        Programmer
        • Jun 2016
        • 10
        Originally posted by SMDFlea
        @SMDFlea
        as its user said it shut down itself , turning it on only shows power lights and other lights like caps lock .. NO DISPLAY AT ALL , then he sent it to someone else to repair .. during repair he didn't use hp flashback or any backups ... used a programmer without knowing it need serial and nvram .. now pc no sign of light or anything ... its totally dead ..
        • m1ch43lzm
          • Mar 2019
          • 1126
          • Peru
          Unfortunately cannot find BIOS/drivers update on HP website (EDIT: I found them, on a different page), as HP has removed support for older models, the serial number points to a different model as HP has reused it... that happens often for laptop models prior to 2015-2016
          HP PartSurfer website with your S/N mentions 2 models: HP Pavilion 15-p213nk, and HP Laptop 15-fd0682TU
          Found a BIOS update sp92961.exe searching for HP Pavilion 15-p200, I extracted it but there are 5 different BIOS, i can't tell which one is correct without the original BIOS dump
          https://support.hp.com/ie-en/drivers...59?sku=L1S95EA
          https://ftp.hp.com/pub/softpaq/sp925...00/sp92961.exe
          Make a backup of whatever is flashed on the BIOS chip first and post it here
          Try 02292 first, it will be missing S/N and model name as that info is likely lost when the previous tech flashed it without making a backup first
          Also check this thread: https://www.badcaps.net/forum/troubl...ve-bios-needed
          • hicham07
            Programmer
            • Jun 2016
            • 10
            m1ch43lzm Thank you so much bro i will try those flashes tomorrow and i will keep you updated really thank you <3
            about the original backup i will ask who repaired it if he made a backup or not <3
              • 22283
              15-p213nk Intel Core i3-5010U - Broadwell
              0227A Bay Trail
              0227D Lynx Point-LP
              02291 Lynx Point
              02292 Wildcat Point-LP (Broadwell)
              02299 Wildcat Point-LP (Broadwell)
              • hicham07
                Programmer
                • Jun 2016
                • 10
                i've found its original backup (The one that light blinking ) can you know which version is it ? and how to fix its serial and model data ?
                • m1ch43lzm
                  • Mar 2019
                  • 1126
                  • Peru
                  It's 02292
                  DMI 72E000-72E0FF
                  Copy/overwrite that range with hex editor to the clean BIOS
                  Attached BIOS with S/N inserted
                  5CD5253TW5
                  L1S95EA#BH4
                  • hicham07
                    Programmer
                    • Jun 2016
                    • 10
                    Originally posted by m1ch43lzm
                    It's 02292
                    DMI 72E000-72E0FF
                    5CD5253TW5
                    L1S95EA#BH4
                    Really Thank you bro <3 and too all here who helped me you are the best ... <3
                    i edited it myself as you said first
                    • hicham07
                      Programmer
                      • Jun 2016
                      • 10
                      The problem now FAN speed is not slow and not very high .. and display show nothing at all and even keyboard doesn't show lights ..
                      i think its due to the missing AA 55 its missing even in backup file and 02292 has it ... it add 1 kb to the bin file ... i hope this time it will show something really thank you for your help guys
                      Click image for larger version  Name:	image.png Views:	0 Size:	7.6 KB ID:	3709366
                      • m1ch43lzm
                        • Mar 2019
                        • 1126
                        • Peru
                        That's the issue, it shouldn't add anything when you paste the offset with hex editor, instead it should be replaced, Paste overwrite
                        Try post 9 as is, I already added the S/N
Name:	Captura de pantalla 2025-08-21 183717.png
                        • hicham07
                          Programmer
                          • Jun 2016
                          • 10
                          Click image for larger version  Name:	Captura de pantalla 2025-08-21 183717.png Views:	0 Size:	89.2 KB ID:	3709373
                          i've tried your's and it turn on with fan speed and it show nothing at display ... and even plugging keyboard it doesn't show any lights only FAN working ..
                          • m1ch43lzm
                            • Mar 2019
                            • 1126
                            • Peru
                            Attempt #2, original backup with replaced BIOS region from F.36, ME region unchanged, S/N inserted
                            Also try cleaning contacts on RAM, test RAM in another slot
                            • hicham07
                              Programmer
                              • Jun 2016
                              • 10
                              Now the fan spinning for seconds and then turn off really strange issue ... No keyboard lights .RAM cleared and even tried new RAM modules .. Could it be EC?
                              • m1ch43lzm
                                • Mar 2019
                                • 1126
                                • Peru
                                Last attempt, try version F.36, this one is extracted from HP website
                                Try it as is, then worry about adding S/N later, give it few minutes for initial boot
                                Make sure you erase the BIOS chip before writing the new file
                                If that doesn't work check for hardware problem
                                • hicham07
                                  Programmer
                                  • Jun 2016
                                  • 10
                                  I think its due to EC firmware ...
                                  bios is totally okay with the flashes u gave
                                    • 22283
                                    EC
                                    • Bloodhoundje
                                      HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                      by Bloodhoundje
                                      I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                      I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                      After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                      I have desoldered the bios chip (GigaDevice...
                                      03-16-2024, 03:12 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • cr4zychriss
                                      by cr4zychriss
                                      • Rebrand: PC Specialist
                                      11-14-2025, 04:04 PM
                                    • sssssssssssssss
                                      Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                                      by sssssssssssssss
                                      I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                                      Symptoms:
                                      • Laptop powers on but no display at all (completely black screen)
                                      • Caps Lock blinks twice with a pause, then repeats continuously
                                      • F12 LED stays on permanently
                                      • No POST, no boot sequence, nothing on screen
                                      Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                                      What I've tried:
                                      • Hardware reset (battery removal, power
                                      09-04-2025, 06:45 AM
                                    • pirati
                                      by pirati
                                      10-27-2025, 04:20 PM
