DELL PRO 14
  • Jm7016
    • Mar 2025
    • 5
    • Mexico
    DELL PRO 14
    Good afternoon, could you help me unlock this laptop? Model: Dell Pro 14
    Service Tag: CFVDCB4
    Board Number: 243082-1
    It has two 256-bit BIOSes. I'm leaving the files. I hope you can help me. Thank you.
  • peste
    • 12859
    • ROMANIA
    post full name and model, etc.
    • Jm7016
      • Mar 2025
      • 5
      • Mexico
      Modelo: Dell Pro 14 Pc14250 Etiqueta de servicio: CFVDCB4.
      NĂºmero de placa: 243082-1 8FWYP$LA
      Sorry, that's fine.
      • Jm7016
        • Mar 2025
        • 5
        • Mexico
        Please can you help me, I already tried and I couldn't unlock it.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
        • lalle-
          Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
          by lalle-
          Hello!
          I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
          [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
          I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
          The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
          I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
          08-11-2024, 02:01 PM
