BIOS for ASUS TUF Gaming A15 FA507NU
  • Michael Angelo Dorio
    Wanderer
    • Feb 2025
    • 11
    • Philippines
    Do you guys have the bios for a laptop model: ASUS TUF Gaming A15 (2023) - FA507NU ?
    I have an issue with BIOS corruption or BIOS password bug
  • hoaca388
    Badcaps
    • Jan 2022
    • 11732
    Post original backup bios and serial number.
      Wanderer
      • Feb 2025
      • 11
      • Philippines
      Here buddy
      SN: R3NRCX03K989119
      Thanks in advance
        Wanderer
        • Feb 2025
        • 11
        • Philippines
        In addition to that:
        I set up a bios password, and later on, I, removed the password, setting the new password as blank. and now it keeps asking me for the password to type in. blank is not accepted, entered 3 times and it freezes, CTRL + ALT + DEL will allow me to restart, old password is not accepted either.
        • peste
          • 12786
          • ROMANIA
          Here buddy
          SN: R3NRCX03K989119
          Thanks in advance
          this is not the bios, look for another bios chip and post the content.. also post the motherboard model..
          • peste
            • 12786
            • ROMANIA
            look for another bios chip, that's something else..look on both sides of the motherboard..maybe under the radiator..look for another chip..
              Wanderer
              • Feb 2025
              • 11
              • Philippines
              Can you please ell me what it is then? or what are the error logs I can check before i get back to this post again? so we can save your time back and fort.
              How about this file?
                • 20873
                That is the Nvidia vBios
                  Wanderer
                  • Feb 2025
                  • 11
                  • Philippines
                  Oh Got it. Thanks for that information, thought this Windbond chip is for the system bios.
                  Guess its time to open up the radiator like what "peste" said. I'll get back once I was able to get something. Can you teach me on how can I confirm if i have the right chip? any documentation will do, but learning from the masters based on experience is much better.
                  • noname2024
                    • Aug 2024
                    • 240
                    • CỎ MỸ XỊN
                    Here buddy
                    SN: R3NRCX03K989119
                    Thanks in advance
                    try
                      Wanderer
                      • Feb 2025
                      • 11
                      • Philippines
                      Originally posted by noname2024
                      try
                      Cheers man. I need to find what chip to clip for now. Appreciate the file.
                      Update: I was able to do a BIOS update last night, but in user mode only. I cannot change anything from BIOS configuration now.
                      Last edited by Michael Angelo Dorio; 02-14-2025, 07:27 AM. Reason: checked bios version
                      • mefausto
                        • Jun 2023
                        • 16
                        • italy
                        Hello everyone.
                        I need the bio for Asus model fa507nu- lp131.
                        The keyboard lights up but I have nothing on the screen.
                        I attach a dump of the Windbond chip that I found on the top of the motherboard, I'm not sure if it's the bios.​
                          • 20873
                          Originally posted by mefausto
                          Hello everyone.
                          Thread merged. Read https://www.badcaps.net/forum/troubl...before-posting ,and type the laptop serial number
                          • mefausto
                            • Jun 2023
                            • 16
                            • italy
                            Sorry, I knew this post but I thought it was actually about a different model.
                            the serial number is: S1NRCX002128019​
                            • mefausto
                              • Jun 2023
                              • 16
                              • italy
                              try
                              Hi, I saw that the file has the extension "312", if I wanted to try it should I rename it to .bin?
                              • csori23
                                • Nov 2018
                                • Slovakia
                                Hello. I need a working bios file.
                                After setting secure boot, I received a black screen, keyboard lights up, charging and power leds are on, fans are working.
                                The bios reading did not bring acceptable results.
                                I used a ch341a black programmer which has been modified/improved and works at 3.3 volts. Using a 1.8 adapter, the result is 00 characters, then I read it without an adapter, so also at 3.3 volts, so I get FF characters in the entire file.
                                I use AsProgrammer 2.1.2 which supports the chip -
                                xmc 25ru256c which works at 1.8 volts.
                                I tested the chip on the motherboard with the WSON8 connector.
                                I don't know what could have happened, I would really like if someone could help. It would be great to read the original bios content.
                                Laptop: asus tuf gaming FA507nu - lp054
                                SN:R6NRCX02B87824E​
                                • csori23
                                  • Nov 2018
                                  • Slovakia
                                  I managed to read the corrupted bios with another programmer. I would be very grateful if someone could help me.
                                    Wanderer
                                    • Feb 2025
                                    • 11
                                    • Philippines
                                    Making an update on this. I'm unable to reflash my BIOS. Just got lucky, I was able to use the old password I've been using since before, and I got in! Weird stuff happens, I feel like an Idi0t all month.
                                    Guess I'll start backing up my working BIOS now. This ticket is resolved.
                                    • huichoger
                                      • Apr 2021
                                      • 8
                                      • México
                                      Hi can somebody help me I have an Asus TUF FA507NU-LP116W with
                                      S/N: S5NRCX01M408198
                                      My Laptop stopped working, I get a black screen with lights on the keyboard and thats all, no problem with RAM or SSD, hope somebody can help,
                                      • lapfix
                                        • Mar 2020
                                        • 2720
                                        • my workshop
                                        Try this new virgin bios
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • smallvhin
                                          ASUS B150 PRO GAMING AURA help bios updating
                                          by smallvhin
                                          Master help to fix my bios stock in "bios is updating" I already update my bios to first release and latest but no luck.
                                          more thanks
                                          bios file
                                          ec file...
                                          07-14-2025, 10:51 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                          ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 09:01 AM
