๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
  • macabook
    • Sep 2024
    • 38
    • France
    Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
    ๐Ÿงฉ Initial Issue
    • External display (HDMI) shows nothing
    • No POST beep, no boot sound
    • Screen changes shade slightly on power ON/OFF, so panel receives at least minimal power/signal
    Basic Power Checks
    • All power rails to CPU, GPU, PCH confirmed present
    • Resistance on coils:
      • CPU: Low (a few ohms, normal)
      • GPU: ~0.5ฮฉ dropping slowly to 0 โ†’ verified normal on other working boards
    • Injected 0.9V at GPU rail, 2.5A โ†’ no shorts, nothing heating up
    • Signals present:
      • GPU_ON = 1.8V
      • SYS_PWR_OK = 3.3V
      • PLT_RST# = 3.3V
      • PEX_RST# = ~1.73V (pulled up by 2.2k to 1.8V)
      • GFX_CLKREQ initially 3.3V โ†’ drops to 0.02V after startup
    • GFX_REFCLK pair measured at ~1.5 MHz, ~0.53V โ†’ not sure if itโ€™s ok ?
    Firmware Work So Far (using CH341A and neoprogrammer)
    • Flashed BIOS (16MB image from MSI site) โ†’ No change
    • Also tried a cleaned ME version of BIOS from vinafixโ†’ machine became completely unresponsive
    • Reflashed EC firmware separately โ†’ recovered initial state
    • Then:
      • Reflashing BIOS seems to overwrite EC (even when EC is flashed first)
      • Every time I flash the BIOS, comparing EC dump shows mismatch at end
      • Suggests BIOS contains embedded EC block that's automatically flashed during boot/reset
    EC + BIOS Interaction Observed
    • Using HxD hex editor, I confirmed BIOS file contains partial EC firmware blocks
    • Not all segments of standalone EC file are present in BIOS
    • This raises the possibility of:
      • BIOS containing an incomplete or compressed EC loader/firmware
      • EC auto-update logic triggered on reset
      • Mismatch causing EC corruption or incorrect operation
    New Symptom
    • After reflashing BIOS + EC to MSI stock versions:
      • Laptop powers on, then shuts down after ~1 minute
      • PCH gets very hot
      • If cooled (with freeze spray), board stays on longer โ†’ seems thermal-triggered
    What is the actual situation
    After trying multiple combinations of cleaned ME bios and EC firmware from backup and MSI site nothing is working I canโ€™t even go back to the initial situation by re-flashing backups.
    • power sequence is ok until SLP_S5# which is missing
    • Checked 32.768 kHz RTC crystal โ†’ present and stable
    What I Need Help With
    1. Is the EC firmware in the BIOS image complete or partial? there is a hardware reset button that suggests a firmware reset, but from where ? I couldnโ€™t find any other bios chip
    2. Is there a documented method to disable EC auto-flash from BIOS?
    3. Could EC/BIOS mismatch explain the missing SLP_S5# or PCH overheating?
    4. Is there a known good version combo for EC firmware + BIOS for MS-17E71?
    5. Has anyone seen a board that powers on but PCH overheats due to EC misbehavior?
    Files Available
    • Original 16MB BIOS dump from board (original.bin)
    • Official MSI BIOS file (E17E7IMS.10C.bin)
    • Official MSI EC firmware (MS-17E71.107.bin)
    • Cleaned ME version of BIOS
    โ€‹
  • Mando47
    [REQUEST] TongFang GM7RG7M / MIFCOM AG7 - Original BIOS and EC firmware
    by Mando47
    I am requesting a verified original BIOS dump/package and matching EC firmware for a TongFang GM7RG7M laptop.
    Machine information:
    - Retail model: MIFCOM AG7 Laptop
    - Barebone/motherboard: TongFang GM7RG7M
    - SKU: GM7RG7M
    - Serial number: GM7RG7M2223100968
    - Motherboard/PCB code: FBM-GM7RG7M0026PCS
    - CPU: AMD Ryzen 9 6900HX
    - GPU: NVIDIA GeForce RTX 3070 Ti Laptop GPU 8 GB
    - RAM: DDR5-4800
    - Original SSD: WD Blue SN570 1 TB NVMe
    - Original adapter configuration: approximately 280 W
    Original...
    09-13-2026, 12:14 AM
  • Boardview and Schematic Bot
    How To Check BIOS / EC firmware version for MSI notebook & Update it
    Not sure how up to date this is....
    How To Check BIOS/EC firmware version for MSI notebook?
    Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
    1. How to check BIOS/EC version by Help Desk?
    1.1. Open MSI Help Desk.
    Note: Help Desk is a built-in application for MSI notebooks. If you couldnโ€™t find this software in your Windows system, please download and install MSI Help Desk from product.
    1.2. Click the [System Info].
    1.3. BIOS and EC firmware version will display on screen.
    03-27-2026, 01:12 PM
  • Tesla
    Dell XPS-15 (9520) Mostly Bricked after common BIOS-Firmware upgrade - Full Repair Log
    by Tesla
    I have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
    I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here...
    03-19-2026, 07:51 PM
  • silentbogo
    HP Z240 need BIOS and EC firmware
    by silentbogo
    Hello everyone. I have a Z240 workstation, and after a power outage it had a bad PSU(already fixed it), and a corrupted BIOS. Initially I had 2.2 blink code, which indicated corrupt DXE region.
    Did a full dump of the original firmware, replaced BIOS region with version N51 from HP website, and now the error code is 5.3(EC firmware unable to communicate with BIOS).
    Flashing the original one as a sanity check also didn't revert the error code(still 5.3). The original firmware version is N01(supposedly it wasn't updated since the original owner bought it).
    I'm wondering...
    12-16-2025, 06:55 AM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
