Thinkpad P53 'Discrete' selected in BIOS
  • Michael Justin Barcenas
    • Jun 2025
    • Philippines
    Hi, I do have the same problem with tuxstevo, however this laptop gives an error beep when I set the graphics mode to Dedicated and won't boot. I have to reflash the bios for me to use it again. I bought this laptop off fb marketplace, it works well but on windows the rtx 4000 is not being shown. On linux it is shown on neofetch but is not present in gnome-system-monitor. I tried installing the drivers for windows, the installation completes but then when I launch the NVIDIA RTX Desktop Manager, it shows an error. I do have a working copy of the bios with the firmware and bios being in the latest version.
    This is the Serial Number: PF1T34NK
    • tuxstevo
      • Oct 2024
      • 14
      Sorry about the delay in getting back, it took me a while to find a suitable pogo clip and then some practice to get a good dump but this appears to be the one if you could be so kind as to have a look and see if you can do anything with it.
      Thanks,
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        Thanks,
        P53 Laptop (ThinkPad)_Type N/A
        Serial_N/A
        • tuxstevo
          • Oct 2024
          • 14
          pf-2BQB4X
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Joluvillas
            Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
            by Joluvillas
            Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
            06-18-2024, 10:35 PM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
