ASUS Zenbook UX6404VV-M3005W
  • Ellos
    • Jun 2025
    • Why?
    remove bios password, i tried saving current bios with aptio 5 afu but tool can't read bios content so i decided to get some help before doing smthing irreversible,
    SN=R4N0CX01M525140, CN=J1WJ, MFD=2023-04, P/N=90NB11J1-M00050
    post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • peste
    • 13924
    • ROMANIA
    post the original contents of the bios chip..
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    • pirati
      by pirati
      10-27-2025, 04:20 PM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
