HP EliteBook 855 G7 Bios unlock
  • aluminiumdisulfid
    • 26
    • DE
    I have a EliteBook 855 G7 here,
    took a dump from both Winbond Bios Chips.
    Is it enough to remove the Password section from the bottom bios chip?
    Or does the EEPROM on the top side have to be modified as well?
    Thanks in advance!
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1224
    • France
    Re: HP EliteBook 855 G7 Bios unlock
    Thanks in advance!
    try
    • aluminiumdisulfid
      • 26
      • DE
      Thanks Maxpower3...but
      Is it possible that my solder connection of the top EEPROM is now bad?
      Or is it likely something else?
      It also displays something about "Protected by HP Sure Start" or something like that when powered on.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1224
        • France
        sorry retry
        • aluminiumdisulfid
          • 26
          • DE
          Nope, does not help.
          Also restoring my original backup does not restore the previous status without this error.
          https://www.badcaps.net/forum/showpo...&postcount=608
          1 flash 16MB with a good one (no backup password inside)
          2 FLASH 32MB WITH CLEAN R70(extracted from bios update exe file) BIOS REGION using intel FIT ( you should get manufacturing programming mode at this step)
          3 FLASH ORIGINAL 32MB UNLOCKED by RethoricalCheese Unlocker
          dycc seems to describe here what might help, but I think I don't know where to get the good ones from...
          The mainboard is a 6050A3200201-MB-A01(A1)
          • peste
            • 12734
            • ROMANIA
            extract the 16MB bios from the update on the site and write it on the 16MB chip, and for the 32MB bios ..cut from the original 16MB bios and, join the 16MB bios extracted from the site with the HxD program and try ..
            • aluminiumdisulfid
              • 26
              • DE
              thanks @peste,
              but I actually don't have a 16mb chip. At least I'm not aware of it and can't find another eeprom.
              I have located two Winbond 25Q256... chips with 32mb each so far.
              One on the bottom (U367) and one the top (U365/U366).
              I extracted the S77_01030100.bin from the HP support site...but the included bin has 37.8mb, which is more than my 32mb chip.
              Do I have to remove parts of this bin or extract it some other way?
              • aluminiumdisulfid
                • 26
                • DE
                @peste, could you please give me another hint?
                Do I need a special tool to extract the bios from the update?
                • matusiq
                  • Dec 2020
                  • 58
                  • Slovakia
                  Have U tried to run the BIOS Update in Windows ?? Or You can not access windows due to the password ??
                  The laptop has AMD CPU right ??
                  • peste
                    • 12734
                    • ROMANIA
                    all you need is the HxD program.
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      855 is AMD so it is a bit different. Extract 32MB from update and write it on both chips, I guess. You could read both chips and take a look what they contain, then you might know whats the right thing to do.
                      • aluminiumdisulfid
                        • 26
                        • DE
                        Honestly I didn't try to update it before, but can try if I get it back into a running state.
                        Yes it's an AMD CPU.
                        Ok, but the firmware.bin from the HP bios update is still about 4mb to big for my bios chips.
                        I checked the contents a bit and it seems to me that the last 4mb contain some things regarding webcam stuff...maybe an appended firmware update or something like that.
                        Did you encounter something like that before?
                        So I cut the trailing 4mb off and flashed that to both chips.
                        All the laptop did was blinking yellow...
                        Now I'm not able to flash U367 anymore with my probe...will try to desolder it tomorrow.
                        Could I have burned something with my previous test?
                        Next step will be to flash both of my backups back and see if I can get it back into its original state. But then I'm kind of out of ideas again.
                        • aluminiumdisulfid
                          • 26
                          • DE
                          Okay, flashed back my backups, that I took before doing anything at all with this laptop...
                          Not it starts up again...don't know what was wrong yesterday, I guess it was too late.
                          * HP Logo with "Secured by HP Sure Start" is displayed
                          * Info screen "the last steps of a bios update are in progress..."
                          * Error Page " / There is a problem with the HP Endpoint Security Controller on this unit...contact support...
                          If I press ESC now I can access the Bios (don't actually know why the password is gone), can disable and reset everything regarding security and stuff, but it keeps showing that "HP Endpoint Security Controller Problem" after every start.
                          Any Ideas?
                          • KenanT
                            • Mar 2017
                            • Nederland
                            Hi, i have also one bios password to go, anybody with a clean file?
                            • keczuk
                              • 83
                              • WWW
                              @KenanT i can help, send only https://www.badcaps.net/forum/attach...2&d=1622755930 this bios from back of motherboard.
                              • abdelilahocs
                                • Nov 2018
                                • 119
                                • morroco
                                Bios attached
                                • bigman4hacking
                                  • Jul 2013
                                  • 6
                                  • Aswan
                                  Re: HP EliteBook 845 G7 BIOS Pass
                                  Hp 855 g7 passdword on 2 bios chips can you unlock for me
                                  • satishkumar
                                    • Sep 2015
                                    • 164
                                    • India
                                    Originally posted by bigman4hacking
                                    hp 855 g7 passdword on 2 bios chips can you unlock for me
                                    • bigman4hacking
                                      • Jul 2013
                                      • 6
                                      • Aswan
                                      Originally posted by satishkumar
                                      I can't extract it
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11700
                                        I can't extract it
                                        Why ? Update your winrar.
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • clrscr
                                          Need unlock bios hp elitebook 835 G11
                                          by clrscr
                                          please help me unlock bios password hp elitebook 835 G11
                                          S/N: 5CG50434RD
                                          thanks!...
                                          06-04-2025, 09:38 PM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • Bharath Ram
                                          HP Elitebook MT45 Bios Unlock
                                          by Bharath Ram
                                          Hi
                                          Can someone please unlock the attached bios file
                                          Laptop: HP MT45
                                          Chip: W25Q256JV
                                          Thanks...
                                          06-21-2025, 09:09 PM
