ASUS S533EA-BN108 BIOS
  • MentenantaRO
    • Apr 2023
    • 16
    • Roumania
    Device: Laptop
    Brand: asus
    Model: S533EA-BN108
    SN: M3N0CV07K190108
    Request: clear me
    Bios attached!
    Fault : Hello, after a failed attempt at Windows update, with a BIOS update, the laptop won't start! Thank YOU!
    • 21984
    Originally posted by MentenantaRO
    Device: Laptop
    Brand: asus
    Model: S533EA-BN108
    SN: M3N0CV07K190108
    Request: clear me
    Bios attached!
    Post the motherboard model number, and a picture of the QR code on the motherboard, similar to this one -> https://www.badcaps.net/filedata/fetch?id=3261244
    • hoaca388
      Badcaps
      • Jan 2022
      • 12340
      Device: Laptop
      Brand: asus
      Model: S533EA-BN108
      SN: M3N0CV07K190108
      Request: clear me
      Bios attached!
      ASUS X521EA
      • MentenantaRO
        • Apr 2023
        • 16
        • Roumania
        X421EA R2.0
        • MentenantaRO
          • Apr 2023
          • 16
          • Roumania
          hoaca388 - is not starting!​
          • MentenantaRO
            • Apr 2023
            • 16
            • Roumania
            It may be misread, I read it twice, I also attached version 2
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • davidebeatrici
              Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
              by davidebeatrici
              I had 3 people contact me in a week because Windows suddenly didn't boot:
              As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
              The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
              Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
              06-17-2025, 12:59 PM
            • jinki_dadou
              ASUS ExpertCenter D700MD need update bios
              by jinki_dadou
              helle
              in have asus desktop
              model : D700MD-5124000950
              CPU i5 12400
              I wanted to upgrade the processor i7 13700
              when I change the processor show black screen and fan spinning fast
              i ask asus technical support
              the answer : include microcode in the latest update bios
              he give me file 1 update bios
              2 microcode
              2 fils in tha attachments please help me
              ( sorry for my dab english )...
              05-18-2025, 02:20 AM
            • Zarithya
              Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
              by Zarithya
              I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
              11-02-2025, 06:26 AM
