Need help with corrupted BIOS (Ver: F.75) for HP 15-BS113dx Product ID: 3PL52UA
  • Alex_450
    • Oct 2015
    • 9
    Hope someone will help. I was trying to update BIOS Version from F.33 to F.75 and during update we had a power surge and now laptop turns on, i can hear cooling fan, but will not POST. I tried creating Recovery USB Drive and it didn't work. What do I have to provide?
    Serial Number CND805916N
  • peste
    • 13924
    • ROMANIA
    post S/N, full name and model, motherboard model, product numberetc.
    post the contents of the bios chip even if it is corrupted..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
      • 22279
      As recovery hasn`t worked you will have to use an SPI programmer to make a backup and flash a new bios to it. You will have to find the bios chip on the motherboard and indentify what type it is, SOP8 or WSON8 .Then buy a programmer, and if you have no way of desoldering the chip then you can try to use a test clip , SOP8 clip or WSON8 pogo adapter .You can buy seperately or get it bundled with the programmer. We have some info about choosing a programmer, backing up etc https://www.badcaps.net/forum/troubl...21#post1622421 ,and you will find loads of programming guides on youtube.
      • Alex_450
        • Oct 2015
        • 9
        Laptop model number is HP 15-BS113DX, Serial number is CND805916N​ Motherboard part number is L15871-601. As far as I understood you correctly, in order to post the contents of BIOS Chip, I need to unsolder i, Use CH341A programmer or which one would you recommend to get contents of the BIOS Chip, correct????
        • Alex_450
          • Oct 2015
          • 9
          Question about Programmer. My friend has Chip Master 6000 XPu, will it work or I need a different Programmer?
          Plus, I do need a link for CH341a software that is compatible with W10
          • Alex_450
            • Oct 2015
            • 9
            I will be using Chip Master 6000 Xpu programmer and my question is which file (See attached) do I need. After creating BIOS Image for version F.75, there are 5 .BIN files and 5 .sig files. I am not allowed to upload either .BIN or .SIG files, but here is the attached picture.
              • 22279
              Make a backup of the corrupt bios first and post it here in a zip or rar. If the BID (08***) number is still in the corrupt bios we will know which one to recommend flashing, and also if the DMI info (serial number, feature byte, windows key) is still readable we can copy that to the new bios.
              [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
              • STKR123
                The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                by STKR123
                Greetings badcaps community,
                I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                I learned that desoldering...
                10-29-2024, 06:03 AM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • FalconPunch
                Surface Pro X 1876 Bios corrupted
                by FalconPunch
                Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                08-09-2025, 03:56 AM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • cr4zychriss
                by cr4zychriss
                • Rebrand: PC Specialist
                11-14-2025, 04:04 PM
