BIOS FILE for AORUS 15P XC Please
  • Dr Techno
    • May 2025
    • 7
    Hi Guys,
    I need a BIOS file for a AORUS 15P XC please. It has i7-10870H and RTX 3070. Motherboard is ga-rx5lxc rev2.0. The Bios chip is a Winbond W25R256JVEQ​. This chip has a 32MB capacity however the official bios from there website only has a 16MB bios which cant be right. It currently has a black screen issue and doesn't display to external display. If anyone has a bios file for this laptop it would be greatly appreciated.Thanks in advance!
  • peste
    • 13600
    • ROMANIA
    Originally posted by Dr Techno
    Hi Guys,
    post S/N, etc.
    post the contents of the bios chip even if it is corrupted..
    • Dr Techno
      • May 2025
      • 7
      Thanks for getting back. I have attached my file here. i am new to this so any help would be much appreciated. Bios chip is a Winbond W25R256JVEQ. S/N is SN21130J002059.
      • Dr Techno
        • May 2025
        • 7
        Motherboard is GA-RX5LXC Rev:2.0
        • hoaca388
          Badcaps
          • Jan 2022
          • 12330
          AORUS 15P XC
          • Dr Techno
            • May 2025
            • 7
            Thank you! I am facing this issue when I am trying to erase my chip: "Current programmer: CH341 Black
            13:04:23
            Erasing memory...
            The process can take more than a minute on large flash memories!
            WARNING, probable erasure failure.
            Execution time: 00:00:00.059
            Do you have any ideas? I am using Winbond W25R256JVEQ​ and NeoProgrammer 2.2.0.1
            • hardware1
              • Sep 2021
              • 2948
              • N/A
              13:04:23
              Erasing memory...
              Your original backup from post #3 doesn't look good. Do you use a clip/clamp or de-solder the chip from the motherboard?
              all donations are welcome,
              • Dr Techno
                • May 2025
                • 7
                I desoldered the chip. Thing is I bought the laptop from ebay so it probably had a corrupt bios when I bought it.
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
