Lenovo V155-15API good bios request
  • AppleLover123
    Mr.Bombastic
    • Dec 2023
    • 64
    Hello guys,
    ive got a Lenovo here that wont display.
    On Google and here on badcaps i didnt found a good bios dump/file so plz if anyone has it.
    I tried disable the onboard ram in bios via SPD removal Tool 1.6. But with the new BIOS it didnt work either.
    My dump is in the attachements
    Please help!
    Last edited by AppleLover123; 05-01-2025, 06:40 AM. Reason: Forgot to attach the original dump
  • peste
    • 13678
    • ROMANIA
    Originally posted by AppleLover123
    Hello guys,
    Please help!
    post S/N, full name and model, motherboard model, TYPE,etc.
    • AppleLover123
      Mr.Bombastic
      • Dec 2023
      • 64
      Lenovo V155-15API
      Model Name:81V5
      Serial Nr: PF2125LC
      MTM: 81V50004GE
      Factory ID: JVHFC1
      MO: PF9XB9B23174
      Motherboard Model: FG542 FG543 FG742 NM-C101
      Rev: 1.0
      2019 - 05 - 07
      • AppleLover123
        Mr.Bombastic
        • Dec 2023
        • 64
        I found a good bios on a discord server but nothing changes when i try it.
        What i didn't mention is that the current at some point isnt changing anymore when i let it run for 2-3 mins.
        That makes me think maybe the onboard ram is faulty... Is there any way to disable it thenclike removing resistors?
        • peste
          • 13678
          • ROMANIA
          bios extracted from Lenovo website update for L340-15API, L340-17API, L340-15API Touch, V155-15API
          DMI 2C9000 - 2CAFFF​
          • AppleLover123
            Mr.Bombastic
            • Dec 2023
            • 64
            (Repost)
            Hello guys,
            i have this laptop here that wont display.
            First thing i did was checking voltages and all are Present.
            After that i tried another ram sticks but they didnt change anything as well.
            Then i tried programming the bios with two different bios files but nothing changed (i used the ch341a without the 1.8v Adapter but I was able to read/write the chip).
            Now i thought it could be a ram issue.
            I flashed a bios with onboard ram disabled (dump attached) and i moved the resistors on the right Place like it's Show in the picture (attached).
            But nothing changed.
            The last thing i did is desoldering the ram Chips from the motherboard but the only thing changed is the current draw that went from 800-900milliamps to 370milliamps.
            What could be the fault here?
            Does it has anything to do with the bios chip? (W25Q64FW 1.8V)
            I have attached a Bios from Lenovos Website that was given to me in a Bios Request...Can someone disable the onboard ram in that bios for me?​
              • 22011
              Try the ram patcher script - https://www.badcaps.net/forum/troubl...20#post3232220
              • AppleLover123
                Mr.Bombastic
                • Dec 2023
                • 64
                Tried it and flashed the bios file... Now the current draw is 900-800milliamps again but still no picture.
                I forgot to mention that ive got the Ryzen 3 3200u model. Maybe its a difference between the ryzen 5 and 3.
                I found new Symptoms like it wont start or shut down when i press the power button.
                It only powers on when i plug the charger.
                It charges fine with about 900milliamps and runs over the battery when powered and charger disconected.
                After a while the current draw goes down to 600 milliamps.
                Voltage on ram module is present.
                Nice tool what you developed. Maybe it will work when i have a dump from a ryzen 3 model.
                • AppleLover123
                  Mr.Bombastic
                  • Dec 2023
                  • 64
                  Hey guys,
                  i did make a few Threads now but I wanted to make it clear.
                  I need a new BIOS Image for this Laptop:
                  Lenovo V155-15API
                  Model Name:81V5
                  Serial Nr: PF2125LC
                  MTM: 81V50004GE
                  Factory ID: JVHFC1
                  MO: PF9XB9B23174
                  Rev: 1.0
                  2019 - 05 - 07
                  Ryzen 3 3200U Model
                  I moved the resistors on the right Place.
                  The Laptop had faulty onboard ram modules and i tried disableing the ram with SPD removal tool 1.6 and RAM patcher from this forum.
                  As it didnt post i scrolled to the entries of the ram Modules in Bios and there were parts that didnt get Set to zero so i Set them to zero and flashed it again (tried 2 times) Laptop wont Post and isnt reacting to the Power Button to turn in off.
                  Can someone disable the onboard ram in the new BIOS Image then?
                  Without the Bios Chip it also turns on but drawing 400 mamps instead of 540 mamps.
                  Also i forgot to mentioned that with the image from Lenovos site i tried the same and didnt work either but the current draw is about 800-900mamps.​
                    SMDFlea commented
                    Editing a comment
                    Thread merged with previous request topic..
                • AppleLover123
                  Mr.Bombastic
                  • Dec 2023
                  • 64
                  No one???
                    • 22011
                    Hey guys,
                    Both threads merged. I think you are beating the dead horse with this ,it`s a hardware problem in my opinion.
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • maeson
                      BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
                      by maeson
                      Hi dear Badcaps-Community,
                      Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
                      I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
                      The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
                      Lenovo Yoga L13 Gen 3 AMD:
                      Lenovo Modell: Type 21BB
                      Artikelnr.21BB006GGE
                      Seriennummer: PW0A6207
                      AMD Ryzen™ 5 PRO 5675U
                      Memory 16 GB DDR4-3200MHz
                      SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
                      10-31-2025, 03:08 AM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • mikosek7
                      Request for a good bios file for Lenovo Thincentre v520s-081kl
                      by mikosek7
                      Good morning!
                      Can I ask for a good bios .bin for Lenovo Thincentre v520s ?
                      Mainboard IB250MH, bios (Windbond25q64jsiq). Windows10 update corrupted the bios. Thank you for your help.
                      04-06-2024, 10:56 AM
                    • personanongrata
                      Help Lenovo Workstation P910 BIOS Request
                      by personanongrata
                      Dear all, I found this forum and this is my last hope. I had a problem with BIOS update though Windows Update - it was stuck for an hour and I decided to restart. Then it bricked. The reason to update was, I had no video on my panorama display. I tried to find a BIOS on my own, but it seems that Lenovo doesn't provide a complete file, only the BIOS section. Is there any chance someone could repair it? I did a backup from the chip, attached. I also tried using another BIOS, slightly different revision. It worked and even I had a display working, but then Windows tried to update once again and it...
                      10-24-2025, 11:19 AM
