I have a JVHFC1 HE430/HE540 Rev 1.0 that has a McAfee BIOS lock and driver encryption. I took a dump of the BIOS and saved it onto my computer. I tried erasing the BIOS and flashing a known good BIOS, but the laptop does not display and image and the fan turns on then off only moments after pressing the power button. The power indicator light also just remains on with no image on screen. Not sure what else I can do from here to be able to have a working accessible BIOS. I have attached a dump of the BIOS that was on the system.
JVHFC1 HE430/HE540 Rev 1.0 BIOS Request
This topic is closed.
Please read the private message i sent you. Thread closed.I have a JVHFC1 HE430/HE540 Rev 1.0 that has a McAfee BIOS lock and driver encryption. I took a dump of the BIOS and saved it onto my computer. I tried erasing the BIOS and flashing a known good BIOS, but the laptop does not display and image and the fan turns on then off only moments after pressing the power button. The power indicator light also just remains on with no image on screen. Not sure what else I can do from here to be able to have a working accessible BIOS. I have attached a dump of the BIOS that was on the system.
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by macabookHello everyone,
07-24-2025, 02:17 PM - Loading...
