Asus Zephyrus s17 GX703HM bios
  • kinoxa
    • Dec 2011
    • 26
    • Kyiv
    Asus Zephyrus s17 GX703HM-KF006 System Bios Dump The BIOS is corrupted.
    serial number: M9NRKD004926387
    Can you share the BIOS file of this machine with me? thanks!​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12336
    • kinoxa
      • Dec 2011
      • 26
      • Kyiv
      Turns on but the screen is dark.
      The only BIOS found on the Internet that works but the drivers for the NVIDIA video card are not installed.​
        • 21955
        Post the motherboard model number, and pictures of the QR code or barcode on the motherboard
        • kinoxa
          • Dec 2011
          • 26
          • Kyiv
          motherboard GX703HS REV: 2.2
            • 21955
            Did you find a QR code ?
            • kinoxa
              • Dec 2011
              • 26
              • Kyiv
              Hi
                • 21955
                Hi
                Try this bios.
                • kinoxa
                  • Dec 2011
                  • 26
                  • Kyiv
                  Everything works fine. NVIDIA drivers installed. Thank you very much.
                    SMDFlea commented
                    Editing a comment
                    You`re welcome :-)
                • uchal12
                  • Jul 2022
                  • 5
                  • Polska
                  Asus Zephyrus s17 GX703HM-002T System Bios Dump The BIOS is corrupted.
                  serial number: M8NRKD00011434C
                  • peste
                    • 13641
                    • ROMANIA
                    read post #6..
                    • uchal12
                      • Jul 2022
                      • 5
                      • Polska
                      I am sending the qr code
                      • uchal12
                        • Jul 2022
                        • 5
                        • Polska
                        someone will help
                          • 21955
                          someone will help
                          Yes. Here`s your new bios + DMI.
                          • uchal12
                            • Jul 2022
                            • 5
                            • Polska
                            Thanks a lot, friend. The laptop has come to life. The graphics card is now visible, and the driver can be installed. There's just one small problem: the laptop reboots six times before it displays a picture.
                              • 21955
                              I don`t think it`s a bios problem, run startup repair and check the ram
                              • uchal12
                                • Jul 2022
                                • 5
                                • Polska
                                I ran the test and everything is fine. I think there's something wrong with the ME Region. When I cleared your BIOS again using Flash Image Tool, the image appeared immediately, but the graphics card wasn't detected again.
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • oragano
                                  ASUS ex-b250-V7 motherboard bios corrupted - by me
                                  by oragano
                                  hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                                  So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                                  i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                                  10-17-2024, 02:53 AM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
