reading EC with svod4 Lenovo NM-D271 issue
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    Hello, im trying to read the EC of lenovo NM-D271 butthe files come up empty after read.
    Im using pinout provided from online database made by Adytia.
    Pin detection is succesfull and i read in 384 size.
    I was hoping to have some help to get the EC read succesfully. might be a pinout issue ? if anyone got more info on this id love to hear it.
    Thanks.
  • peste
    • Dec 2016
    • 13176
    • ROMANIA
    Thanks.
    post S/N, full name and model, TYPE,etc.
    read the forum rules..
    https://www.badcaps.net/forum/troubl...ore-posting​
    • volinakis
      • Jan 2021
      • 2791
      • N/A
      Thanks.
      "pin detection"? just choose NUVOTON in mode of programmer, power on motherboard and hit Read ID. then config nuvoton, choose 384kb and hit Read
      • Pfudaniel
        • Feb 2021
        • 91
        • Netherlands
        Excuses Mod, and thanks for correcting.
        lenovo L14 gen2
        NM-D271
        HL4A0
        • Pfudaniel
          • Feb 2021
          • 91
          • Netherlands
          Thanks for answering. “Power on motherboard” as press power button and turn laptop on?
          • volinakis
            • Jan 2021
            • 2791
            • N/A
            no, just plug in the charger.
            • Pfudaniel
              • Feb 2021
              • 91
              • Netherlands
              I have battery disconnected, plug in lenovo 65charger and followed steps. But still empty read files
              • Pfudaniel
                • Feb 2021
                • 91
                • Netherlands
                Like this
                • volinakis
                  • Jan 2021
                  • 2791
                  • N/A
                  Like this
                  set programmer for 1.8V. I don't know why but setting for 3.3V gives errors, even SIO is powered from motherboard and not programmer. Check again if you set the ribbon cable in right position with a multimeter, is tricky for lenovo.
                  • Pfudaniel
                    • Feb 2021
                    • 91
                    • Netherlands
                    Set to 1.8v . Ribbon cable sits good, checked with multimeter. But still file read is empty.
                    • Pfudaniel
                      • Feb 2021
                      • 91
                      • Netherlands
                      • volinakis
                        • Jan 2021
                        • 2791
                        • N/A
                        what's the problem is with your laptop? and post serial no. as requested by moderator.
                        • Pfudaniel
                          • Feb 2021
                          • 91
                          • Netherlands
                          i checked video's aswell im doign exactly as it shud but something is not right.
                          bioslock
                          sn: PF-3F4G3X
                          • volinakis
                            • Jan 2021
                            • 2791
                            • N/A
                            bioslock
                            sn: PF-3F4G3X
                            use Maxpower3 solution
                            https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
                            • shahnld
                              Lenovo legion 5 pro startup issue
                              by shahnld
                              Good day Experts
                              I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                              A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                              And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                              08-24-2025, 12:31 PM
                            • db80
                              Lenovo Ideapad 5 15ARE05 startup issue
                              by db80
                              Hello friends,
                              I've been racking my brain over the past few months on the following issue:
                              I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                              If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                              Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                              I tried all the common alleged „fixes“...
                              07-06-2024, 05:58 PM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                            • code share
                              Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                              by code share
                              I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                              Here's what I've tried so far:
                              • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                              • Booted successfully on AC power only with the battery disconnected
                              • Visual inspection of the battery — no swelling, burn marks, or connector damage
                              • Battery
                              04-21-2025, 12:50 PM
                            • Nagyesz
                              Lenovo ideapad 3 15IL05 - ram issue
                              by Nagyesz
                              I've encountered an issue I've never experienced before..
                              The Lenovo works perfectly, it has 4gb soldered ram and an additional slot. With just the 4gb the laptop passes all tests, everything is working. However no matter what frequency or capacity of ram I add to the extra slot the display starts artifacting completely randomly in both in the bios and in win and the only solution is to shut down.
                              I've inspected the pins of the extra slot with a magnifying and didn't notice anything unusual. I've also tried multiple ram modules, but the issue is the same....
                              01-11-2025, 05:17 AM
