Hello everyone, please, if anyone has the dump of the ThinkPad T14 Gen 4 Ryzen 7 (SN: PF-4VR7V9) with motherboard NM-F261 rev 1.0, Thank you!
Please Help Dump Thinkpad T14 Gen 4 AMD
Tags: None
When requesting a repair / bios supply you need to post: model, serial number / service tag number, bios backup (even if it is corrupted), description of the error.↵
https://www.badcaps.net/donate -
After a BIOS update, my Lenovo ThinkPad T14 Gen 4 has encountered an issue. Following the update, the computer is not booting properly. Only one LED is blinking, and the screen remains black. Below are the required details for the repair or BIOS replacement request:- Model: Lenovo ThinkPad T14 Gen 4
- Serial Number / Service Tag: PF-4VR7V9
- Motherboard: KT4D2/KP4D5/KT6D2/KP6D5 NM-F261 Rev:1.0
- Issue: The computer is not booting after the BIOS update; only one LED blinks, and the screen stays black.
thank you hoaca388 ,
https://www.badcaps.net/donateComment
Hello. Please help.
First problem: data error 2204 it keeps displaying a date problem
second: Cpu Type Eng Sample Can you change it on Ryzen
Lenovo T16 Type 21K7
Gen 2
NM-F261 rev 0.2
ThanksAttached FilesComment
Hello. Please help.
Gen 2
NM-F261 rev 0.2
Thanks↵
by AhariHi all,
I...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by JoluvillasHi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
Channel: BIOS Requests ONLY!
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
