Asus X420FA Bios
  • Lloydz
    • Apr 2015
    • 27
    • Portugal
    Asus X420FA Bios
    Hello All,
    I'm having trouble with a bios, already downloaded from official site, however, it's not a one that i've come around, it seem like it's split in different places. Already tried to make a new one, but didn't work. Since the original anomaly is that it doesn't post, i'm not confident that did it right, at first.
    I'll post the original dump from board, the file from site and the one that I made. If anyone could help me confirm if it's OK or make me a clean one i would be thankful for that.
    The machine is an Asus X420FA with SN: K5N0GR00Y298186
  • noname2024
    • Aug 2024
    • 295
    • CỎ MỸ XỊN
    hoaca388 SMDFlea
    • Lloydz
      • Apr 2015
      • 27
      • Portugal
      Since last post I've analised my dump, and I think it has been corrupted. Don't know if it was before or during the reading of the chip. Since then I already erased it, so there no way to get back the original. Can someone help me? saw some dumps on another sites, but I don't have acess.
      • Lloydz
        • Apr 2015
        • 27
        • Portugal
        Meanwhile solved it, I'll attach a dump with clean region if anyone needs it
        • lrouw84
          Asus vivobook s510ua bios changed to x510un
          by lrouw84
          Hi there,
          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
          01-28-2023, 01:31 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • maciek1221
          Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
          by maciek1221
          Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
          Config:
          Model: Asus G512LV-HN235T
          Platforma: G532LWS rev. 1.3
          CPU: intel i7-10870H
          GPU: nVidia Geforce RTX2060/...
          03-07-2024, 07:54 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Technodoc
          ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
          by Technodoc
          Asus laptop G614JZ-N3012W Rog Strix with i7
          Mainboard G634J-PMV-VGT
          6050A3441302-MB-A01
          2023-02-10
          Power button works okay....power light goes on
          Red "bottom" leds go on
          Charging led works
          Fans do not spin, capslock key does nothing, screen stays black
          I would like to program the bios again, to rule out a corrupted bios.
          However I run into a size error
          The bios chip is a Winbond 25R256JVEN
          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
          02-24-2025, 04:46 AM
