ASUS A416JAO Bios Request
  • tujuhkalitujuh
    • Oct 2013
    • 27
    • Indonesia
    My Laptop is Asus Vivobook A416JAO
    The mainboard code is X415JA R3.1-VIPS523
    SN: M9N0CX10P07337D
    CN: KLFJ
    The problem is no display
    Please fix and clear-me this dump.
    Wish you all the best. Thanks in advance.
    Bios dump and picture attached
    Don't post pictures unless asked
  • hoaca388
    Badcaps
    • Jan 2022
    • 12280
    SN: M9N0CX10P07337D
    CN: KLFJ
    X415JAB
    • noname2024
      • Aug 2024
      • 291
      • CỎ MỸ XỊN
      SN: M9N0CX10P07337D
      CN: KLFJ
      Model X415JA
      • tujuhkalitujuh
        • Oct 2013
        • 27
        • Indonesia
        Originally posted by hoaca388
        X415JAB
        Thanks for the DUMP
        I am testing it and will update the result.
        • tujuhkalitujuh
          • Oct 2013
          • 27
          • Indonesia
          X415JAB
          Update: This bios is different from the version x415JA used on the mainboard, everything worked except the web cam didn't shown up on Device manager.
          I already tried another x415JAB version but experiencing not working Intel UHD, the driver cant be installed.
          I still need the dump from x415JA version
            • 21692
            bios.
            • tujuhkalitujuh
              • Oct 2013
              • 27
              • Indonesia
              Originally posted by SMDFlea
              bios.
              Thanks for the BIOS master SMDFlea, I have tested this bios and somehow the laptop can't be charged, the laptop only Turned On using battery mode, indicator on taskbar showing the Adaptor detected and LED indicator also turned on, but somehow the Ampere on powersupply showing no significant current than it suppossed to be, only approximately 0,0016A.
              when the battery is empty the laptop went off too.
              I can't check the function on windows due to the battery has ran out and I need to switch back the bios to x415JAB given here before in order to charge the battery first.
                • 21692
                Post a picture of the QR code near the CPU
                • tujuhkalitujuh
                  • Oct 2013
                  • 27
                  • Indonesia
Name:	WhatsApp Image 2025-03-10 at 07.49.24_7ba7538e.jpg
                  here it is
                    • 21692
                    here it is
                    X415JAB is the model from the barcode
                      • 21692
                      here it is
                      Try this one. If you still have any problems its hardware, the bios is ok.
                      • tomy78
                        Tom
                        • Jul 2019
                        • 40
                        • Indonesia
                        Please Repair my bios. reason no display
                        Asus A416JA-BV312TS
                        Board X415JA R2.0
                        LCN0CX00C124499​
                          • 21692
                          Asus A416JA-BV312TS
                          Board X415JA R2.0
                          LCN0CX00C124499​
                          Post a picture of the QR code, like the one at post #9 or scan it yourself and post what it says.
                          • tomy78
                            Tom
                            • Jul 2019
                            • 40
                            • Indonesia
                            case closed. i'm learn to rebuild. thanks
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • grimacelord
                              by grimacelord
                              07-10-2025, 02:52 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • skurvysyn
                              BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                              by skurvysyn
                              laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                              original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                              01-08-2025, 04:45 PM
