Asus FZ50V Bios
  • jorpec
    • Feb 2015
    • 40
    • Portugal
    Asus FZ50V Bios
    Hi, I have a ASUS FZ50V that is completely dead, this happen after an update, i suspect the bios is corrupted.
    I have attached the bios that i read from the chip
    Model: FZ50VX-D56B95SB1
    S/N: GAN0CV16K624428
    BIOS CHIP: 25Q64FV
    Thanks.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    BIOS CHIP: 25Q64FV
    Thanks.
    FZ50VX
    • jorpec
      • Feb 2015
      • 40
      • Portugal
      Originally posted by hoaca388
      FZ50VX
      Thanks, now it turn on, the leds light up but no image it seems is not booting
      EDIT: I let it stay on for some time and suddenly the ASUS logo appeared and the windows loaded
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        The mistake many people make is that they rush things.
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • maciek1221
          Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
          by maciek1221
          Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
          Config:
          Model: Asus G512LV-HN235T
          Platforma: G532LWS rev. 1.3
          CPU: intel i7-10870H
          GPU: nVidia Geforce RTX2060/...
          03-07-2024, 07:54 AM
