Asus Zenbook UX435E - bios request
  • elprojects
    • Mar 2022
    • 12
    • Lithuania
    Laptop Asus Zenbook UX435EAL ; s/n: m8n0cx15h989339.
    It turns on but no image appears, maybe the bios got scared.
    Maybe someone has a working dump?
    Thank you.
    • 21679
    Thank you.
    post your bios backup
    • elprojects
      • Mar 2022
      • 12
      • Lithuania
      Attaching the bios dump.​
      • noname2024
        • Aug 2024
        • 291
        • CỎ MỸ XỊN
        TRY
        • elprojects
          • Mar 2022
          • 12
          • Lithuania
          Originally posted by noname2024
          TRY
          I tried, nothing happened, everything is the same, the computer turns on, but there is no image on the LCD screen or via HDMI, the CPU heats up, the fan starts spinning, the white LED is on, but there is no image, maybe the problem is elsewhere, thanks​
          • LostAndFound
            • Feb 2025
            • 10
            • Latvija
            Need a help unlocking BIOS. Asus Zenbook 14'' UX435E. Board UX435EG Rev.2.0. S/N: 24MM8N0CX16C321334. BIOS chip Winbond 25Q80DV.​
            Thank you.
            • peste
              • 13430
              • ROMANIA
              Thank you.
              this is not the content of the bios chip...look for another chip on the board...the bios chip has 16MB..
              • LostAndFound
                • Feb 2025
                • 10
                • Latvija
                Yea, thanks for info. Found another Winbond chip on board : 25Q128JVPQ. Looks like it is the one I need to dump, but unfortunately can't get clamps on it. Too small contacts, low profile chip
                • peste
                  peste commented
                  Editing a comment
                  Don't post pictures unless asked.
              • peste
                • 13430
                • ROMANIA
                The bios chip must be unsoldered from the board before writing or reading..
                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                solder wires between the programmer and the bios chip..
                here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                • LostAndFound
                  • Feb 2025
                  • 10
                  • Latvija
                  Done. Dumped BIOS twice with special clamps using CH341A. Both hashes was identical. I hope this time it is correct one, as it has AMITSESetup. Unfortunately, my skills in Ami BIOS decryption are poor.
                  If I clearly understood (after some research , these hex values contains boot and bios admin passwords:
                  Code:
                  6F 71 10 E7 64 9A CB 2C 7D 2E 5B 15 A5 09 F0 96 BE 9E C6 B0 03 63 E7 4F 53 53 DF 29 04 6A E6 03
                  10 5F B8 A5 BC 75 08 08 14 BC E6 CA A4 6D C0 9C E3 18 1E 22 03 A6 3B 76 82 3E 13 E1 78 B7 AE 41
                  But still I'm struggling to decrypt them. Your help in unlocking this Asus BIOS is much appreciated.
                  Asus Zenbook 14' UX435E. Board UX435EG Rev.2.0. S/N: 24MM8N0CX16C321334.
                  Best rgds
                  • volinakis
                    • Jan 2021
                    • 2872
                    • N/A
                    Code:
                    Best rgds
                    try pass:
                    ray4uhky
                    71.y25n3
                    USE US KEYBOARD!
                    If doesn't work just fill with 00 the hex values - they are in 2 places
                    • LostAndFound
                      • Feb 2025
                      • 10
                      • Latvija
                      Originally posted by volinakis
                      USE US KEYBOARD!
                      I wish I could, but for some reason USB-A port is not working on this laptop. Anyway thank u very much volinakis​. Will try on monday, when I get USB-A>USB-C adaptor
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • Tika
                        ASUS Zenbook Pro 14 Duo OLED ux8402vu BIOS Unlock request
                        by Tika
                        Hello, Can someone help me unlocking this asus Zenbook Pro 14 32MB Bios, I try to learn it by searching the whole forum but the guide is for 8MB or 16MB non of them are 32MB and I can't figure it out.
                        Laptop Brand: Asus
                        Model code : ux8402vu R2.0
                        SN: R8N0CV212230358
                        Bios chip Gigadevice 25R256E
                        The only problem with this laptop is the UEFI bios locked. I've upload my dump below. Thank you for your help....
                        03-10-2025, 11:31 AM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
