Need bios HP 17-CP0007CA 6050A3260801-MB-A01(A1)
  • cheebster
    • May 2008
    • 376
    Hello, here is the dump from this HP 17-CP0007CA with mainboard 6050A3260801-MB-A01(A1). Chip is a 128MB W25Q128JW WSON8 1.8V
    Device boots to a black screen. Someone said the device was in bios recovery before...
    Serial number is 5cg2023FDJ.
    Anyone has a bios that works for this ? Thanks !
  • volinakis
    • Jan 2021
    • 2877
    • N/A
    try bios extracted from update
    • cheebster
      • May 2008
      • 376
      Hey, that worked ! Simple fix.. I tought edits were needed to make these boots from updates extracted file. Small hickup, when booting it says 'manufacturing programming mode is in unlock mode' and some checksum error but it boots anyway, installing windows now.
      I guess i could re-update the bios from the official package to fix this ? Thanks again.
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        Use BCU (bios configuration utility) for HP and lock MPM. If you also have errors about serial, BuiltID, etc, use the same BCU to write the values. You can find those values in your bios backup starting with hex adress 0x413100
        "simple fix.."? you are a funny guy ... next time do it yourself!
        • cheebster
          • May 2008
          • 376
          Hey, you need to chill out a bit. I was just saying that flashing the bios from the website worked, in comparaison to editing the bios to patch many things. Not need to take it personal sir.. Thanks for your help anyway
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • istvanszasz99
            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
            by istvanszasz99
            Product ID: RZ09-0421
            Motherboard: CH580
            Bios File Size: 32,768 KB
            Dear Forum Readers!
            !!! MY RAZER BLADE...
            11-24-2025, 05:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
