ASUS Zenbook 14 UM425I bios need
  • jheunne
    • Sep 2022
    • 63
    • philippines
    hi i have asus Um425i laptop circling load below asus logo on startup. board id ux425ia rev 2.1 i already flash bios downgrade from 307 to 302 still no luck even in new fresh install windows not boot properly. do you have exttracted bios from supportm asus 311 version bios.
  • peste
    • 13718
    • ROMANIA
    post S/N,post the contents of the bios chip even if it is corrupted..etc.
    • jheunne
      • Sep 2022
      • 63
      • philippines
      SN: 12M L8N0LP00949432C CHIP XM25QU128B
      here is the screenshot
      loading then bsod error
      • peste
        • 13718
        • ROMANIA
        not what model of chip it is... but its content doesn't interest them..
        • jheunne
          • Sep 2022
          • 63
          • philippines
          here is the backup of bios
          hope you can help me this tried everything in support asus UM425I i tried to extract file bios 311 version i check its 17mb buffer size out of range.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12392
            Zenbook 14 UM425IA
            • jheunne
              • Sep 2022
              • 63
              • philippines
              still the same problem status loading logo
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
