HP 240 G8 HEDWIG02-6050A3285801-MB-A01(A1) bios
  • m1ch43lzm
    • Mar 2019
    • 1015
    • Peru
    #41
    Originally posted by NazaMusk
    i am suspecting this could be my corrupted bios.
    SN: 5CG31014HT
    Your file Is EliteBook 840 G1 BIOS
    This laptop has 3 different BIOS update packages on HP website
    https://support.hp.com/us-en/drivers...ber=5CG31014HT
    Checked all 3, only one has support for Tiger Lake CPU (Intel 11th gen), according to HP partsurfer you have TGL i3-1115G4, 3.0GHz,BGA,B-1
    Try
    BIOS ver. F.27
    BID 08819
    First boot may take few minutes
    • NazaMusk
      • Aug 2022
      • 10
      • Nigeria
      #42
      Try
      BIOS ver. F.27
      BID 08819
      Thanks for your response sir, but it didn’t work.
      • m1ch43lzm
        • Mar 2019
        • 1015
        • Peru
        #43
        Which BIOS worked for you with the password? Post a link to it
        • NazaMusk
          • Aug 2022
          • 10
          • Nigeria
          #44
          here it is...but of recent it doesn't display anymore.
          • m1ch43lzm
            • Mar 2019
            • 1015
            • Peru
            #45
            It's the same content as post # 41 (no DMI) but Initialized ME region, maybe you have another fault, check RAM, SSD, etc.
            • laptopgreen
              • Aug 2017
              • 29
              • VN
              #46
              Pls help me build this bios, no display. Thanks
              SN: 5CG1340HMF
              Hp 240G8
              HEDWIG02-6050A3285801 MB A01
              • danito
                • Jun 2016
                • 1139
                #47
                SN: 5CG1340HMF
                Hp 240G8
                try
                • laptopgreen
                  • Aug 2017
                  • 29
                  • VN
                  #48
                  Originally posted by danito
                  try
                  Thanks! Still no image. Maybe hardware
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12396
                    #49
                    Find hardware problem.
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      #50
                      Hi need help rebuild this bios it came with no display
                      MODEL:HP 240 G8
                      PRODUCT ID: 56L14PA#UUF
                      SN# 5CG14532M7
                      BACKUP ORIGINAL BIN NOT TOUCH
                        SMDFlea commented
                        Editing a comment
                        Thread merged.
                    • m1ch43lzm
                      • Mar 2019
                      • 1015
                      • Peru
                      #51
                      Try, BIOS extracted from HP website, DMI+Win key inserted
                      HP 240 G8 Notebook PC (56L14PA)
                      BID 08819
                      BIOS ver. F.15
                      S/N 5CG14532M7
                      DMI 801000-80203F
                      Win key 887000-88703F
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        #52
                        BID 08819
                        BIOS ver. F.15
                        S/N 5CG14532M7
                        DMI 801000-80203F
                        Thanks may I ask what did you use to extract the hp.exe ? It freeze my computer jf i tried to extract those. Trying to practice again forgot how things should be done.
                        • kalilinux25
                          • Mar 2018
                          • 2093
                          • ZAMBOANGA SIBUGAY
                          #53
                          BID 08819
                          BIOS ver. F.15
                          S/N 5CG14532M7
                          DMI 801000-80203F
                          Still no display 3 whites and 2 rapid white
                          blinking on the capslock
                          • m1ch43lzm
                            • Mar 2019
                            • 1015
                            • Peru
                            #54
                            Vesko356 guides
                            https://www.badcaps.net/forum/troubl...e-file?t=12194
                            And https://www.badcaps.net/forum/troubl...flash?t=122195
                            Works for me on another HP laptop, try on another PC or run the .exe on a virtual machine, those HP .exe also crash on an old PC I have with legacy AMI BIOS (not UEFI)
                            For older BIOS versions you may get a warning about vulnerable driver amifldrv64.sys if you run it on latest Win11 version, use a Win 10 VM
                            HP for some reason mixed 3 different BIOS update packages on the website for this laptop...
                            https://support.hp.com/us-en/documen...719-1528356-16
                            On systems that do not have a dual-color light, both long and short blinks are white
                            The red light blinks three times, and then two, short white light blinks (3 long red, 2 short white)
                            This condition indicates a potential memory failure. Reseat the memory module from inside the computer
                            Check RAM, clean RAM contacts with pencil eraser, also check the RAM slot pins if they're soldered properly
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                            • fulaphex
                              Lenovo Thinkpad X13 Gen 3 AMD locked bios
                              by fulaphex
                              hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                              I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                              07-09-2025, 07:04 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
