Help Macbook Pro A1286 820-2915 blank screen
  • marcelofct
    • May 2019
    • 126
    • chile
    Hello friends, I need someone to help me clean ME the bios that I leave attached since the macbook pro a1286 SN: C02FDHXPDFF8V 820-2915 loads the logo and then the screen is left blank, I think it could be bios
    Greetings and thank you very much in advance
  • vladimir1909
    • Apr 2016
    • 25
    • Peru
    I dont think is a Bios related issue. To me sounds more like a gfx issue. Try to boot in safe mode.
    If boots, is not bios but gfx issue
    • vladimir1909
      • Apr 2016
      • 25
      • Peru
      Forgot to attach this modded bios in case is a gfx issue, flash this bios and it will disable the faulty gfx card and use integrated intel graphics.
      • marcelofct
        • May 2019
        • 126
        • chile
        i tried that and same problem ,
        I'll still try again thanks
        • alfredposadas09
          • Aug 2020
          • 342
          • Philippines
          try to perform gmux gpu disable
          • marcelofct
            • May 2019
            • 126
            • chile
            i tried bios your post and works but a wanna try a clear me region , gracias
            • vladimir1909
              • Apr 2016
              • 25
              • Peru
              Glad to hear it worked.
              Abrazo brother
              • clicfix
                • Oct 2023
                • France
                I need your help for A1286 Macbok Pro (820-2850-A), I have password EFI on my bios and I can't restore my MacOS,
                I triyed to read my bios but I didn't find $SVS .
                My bios is a Microchip component SST25VF032B, If someone could explain it to me that would be great.
                Thanks.
                • peste
                  peste commented
                  Editing a comment
                  post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              • peste
                • 15083
                • ROMANIA
                Thanks.
                try this..Change the RAM configuration and reset PRAM three times in a row...
                If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                It only takes 1 minute:
                https://www.badcaps.net/settings/subscriptions
                • clicfix
                  • Oct 2023
                  • France
                  It works!
                  Thank you
                  • vladimir1909
                    • Apr 2016
                    • 25
                    • Peru
                    I have just noticed that the file is unable to download, so here it is again.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • resistor83
                      Macbook pro 15" 820-2915-B 2011 A1286 boot on but black screen
                      by resistor83
                      Hi everyone, I have this 2011 MacBook Pro 15" model 820-2915-B which has a problem.
                      I turn it on, the startup sound is heard but the screen doesn't turn on, not even the backlight. The keyboard lights up after a while and the capslock works. If I press any key I can hear sounds as if the system is booting.
                      I thought it was a screen problem but after changing it the problem remains.
                      What could I do?
                      09-14-2023, 12:38 PM
                    • MagJ_
                      MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
                      by MagJ_
                      Hello Everybody,
                      I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
                      10-09-2024, 02:51 PM
                    • Chrissygizmo
                      Panasonic TX-48CX350B backlights but white screen , blank screen
                      by Chrissygizmo
                      Hi all, I’ve got a problem I hope someone can help me fixi.
                      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                      01-11-2025, 03:18 PM
