Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
  • Nicola Bianchi
    • Jan 2025
    • 15
    • Switzerland
    Hello!
    A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
    No the machine power up, but it stuck in a recovery state and I can not do much.
    Lenovo X1 Nano Gen 1
    Type: 20UN - X021US
    S/N: R9 - 10W2D9
    I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
    So here I am to ask for help.
    I opened the laptop and I found a chip that may be the target, on it I've:
    Winbond 25R256JVEQ (see picture)
    Is this the chip where to flash the bios?
    I downloaded the bios from here:
    https://fwupd.org/lvfs/devices/com.l...N2TET.firmware
    I'm totally new to this topics, so be patient.
    Thank you
    Nicola
    • 21389
    25R256JVEQ​ should be the correct chip. Don`t flash anything to it yet. Make a backup and post it here.
    • Nicola Bianchi
      • Jan 2025
      • 15
      • Switzerland
      Hi, thanks.
      Unfortunately it looks like with my CH341a programmer and flashrom I can not read this chip 🤔
      I need to understand if this is supported or not
      Cheers,
      Nicola
      • Nicola Bianchi
        • Jan 2025
        • 15
        • Switzerland
        Do you have any suggestion about programmer+software that can read&write a 25R256JVEQ chip?
        Thank you,
        Nicola
        • hardware1
          • Sep 2021
          • 2943
          • N/A
          Thank you,
          Nicola
          Have you tried to choose W25Q256JV instead of W25R256JV?
          Are you using NeoProgrammer software?
          all donations are welcome,
          • Nicola Bianchi
            • Jan 2025
            • 15
            • Switzerland
            I'm using "flashrom" (https://www.flashrom.org/) on a Linux OS with the CH341a programmer.
            I need to check NeoProgrammer ....
            Thank you.
            • Nicola Bianchi
              • Jan 2025
              • 15
              • Switzerland
              I managed to read something from the chip using the following:
              sudo ./flashrom --programmer ch341a_spi -c W25Q256JV_Q -r backup.bin
              I read it twice and I got a 32MB file but the md5sum is different between the 2.
              I don't know if this is "normal" or the connection to the chip (is situ with a SOIC8 clamp) is not stable enough...
              I attach the 2 extracted files.
              Thanks a lot.
              Cheers,
              Nicola
              • hobostove
                • May 2023
                • 73
                Looks like a bad connection, those dumps are basically blank. Try again. The file should zip compress to around 10-20MB. Being only 66KB is a pretty clear indicator it's mostly blank.
                  • 21389
                  Thank you,
                  Nicola
                  Try IMSProg https://github.com/bigbigmdm/IMSProg .You can`t use a SOP8 clip as it is. Cut the clamp off completely and then solder the wires to the copper pads or if you want to keep the clamp cut part of the insulation off and solder extra wires to the existing ones ,then solder the new wires to the pads. Keep the wires as short as possible. The other alternatives are to buy a WSON pogo adapter (you have to hold it very steady to get a good backup) or desolder the chip and use a WSON adapter board.
                  • Nicola Bianchi
                    • Jan 2025
                    • 15
                    • Switzerland
                    Yeah, I think my SOIC8 clip is not the right one.
                    Now I ordered a WSON8 tester which should be better.
                    Talk to you soon.
                    Nicola
                    • rumpumpel1
                      • Jul 2019
                      • 159
                      • germany
                      remove the excess solder so as not to bend the pogo pins.
                      • Nicola Bianchi
                        • Jan 2025
                        • 15
                        • Switzerland
                        Hi guys!
                        With the right clip I managed to read the chip consistently, so here what I extracted.
                        binwalk shows some content, which is promising I think.
                        Cheers,
                        Nicola
                        • hardware1
                          • Sep 2021
                          • 2943
                          • N/A
                          Hi guys!
                          Cheers,
                          Nicola
                          Here is your new BIOS file, try it and let me know.
                          • Nicola Bianchi
                            • Jan 2025
                            • 15
                            • Switzerland
                            thank you so much!
                            I did a first attempt to flash the BIOS file, the tool reported back an error, but I tried to boot up the laptop anyway.
                            The result is that he did something different than before: "reading ME Firmware" ... but now it ended up in the same "BIOS Self Healing backup progressing ...100%" state.
                            I will try later to flash it again.
                            See attachment for details if curious.
                            Cheer,
                            Nicola
                            • hardware1
                              • Sep 2021
                              • 2943
                              • N/A
                              thank you so much!
                              Cheer,
                              Nicola
                              I don't use flashrom, but I can see failed in verifying the chip. That means the file on the chips isn't identical with the file that you already programmed.
                                • 21389
                                Try using flashrom agin, and IMSProg, if you get the same error at the same point the chip has a problem. If you get different errors in differnt places it could be you not holding the pogo adapter steady enough.
                                • Nicola Bianchi
                                  • Jan 2025
                                  • 15
                                  • Switzerland
                                  Hi guys,
                                  I did manage to get a successful write!
                                  Unfortunately though, the laptop is still in the same situation, stuck in the "BIOS Self Healing backup progressing ...100%" screen 🤷‍♂️
                                  A couple of notes:
                                  - I had to use W25Q256JV chip type instead of 25R256JVEQ ... maybe this in an issue?
                                  - I used flashrom that for W25Q256JV_Q has only an untested state
                                  .... still that the write succeeded 🤔
                                  Cheers,
                                  Nicola
                                  • Nicola Bianchi
                                    • Jan 2025
                                    • 15
                                    • Switzerland
                                    Hi guys,
                                    me again.
                                    Could it be that the issue preventing the notebook to boot does not resides in the chip we are targeting?
                                    Or it simply may be that I need to try another BIOS image?
                                    Thank you.
                                    Cheers
                                    Nicola
                                    • Nicola Bianchi
                                      • Jan 2025
                                      • 15
                                      • Switzerland
                                      For the records, I managed to recover my X1 Nano using the attached bios firmware using flashrom
                                      sudo ./flashrom/builddir/flashrom --programmer ch341a_spi -c W25Q256JV_Q -w X1_Nano_Gen_1_Laptop_ThinkPad_-_Type_20UN.bin
                                      Thank you for the support!
                                      Cheers
                                      • kmorin
                                        ThinkPad <3
                                        • Apr 2025
                                        Cheers
                                        Hi Nicola! I ran into the exact same issue as you, so I have ordered a programmer and will try to flash the bios firmware you attached. I'm just curious as to where you got this firmware from...
                                        • abhorsen
                                          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                          by abhorsen
                                          Hey guys,
                                          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                          07-06-2023, 10:22 AM
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • HotSaladMan
                                          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                                          by HotSaladMan
                                          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                                          Model : Lenovo ThinkBook 14S Yoga ITL
                                          S/N : MP28JT19
                                          MFG Date : 2022/02/09
                                          Factory ID PRC4
                                          MO : MPNXB26080FX
                                          MTM : 20WE001US
                                          MODULE FCC ID : PD9AX201NG
                                          IC : 1000M-AX201NG
                                          BOARD INFO
                                          FLV34 LA-KO51P
                                          REV : 1B 2020-08-24
                                          Bit of Info
                                          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                                          chip id, so i would always uncheck the id check, so it would bypass the error
                                          i did in fact make...
                                          11-07-2024, 07:46 AM
                                        • pcwhiz24
                                          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                          by pcwhiz24
                                          Model: Lenovo IdeaPad 3 14ADA05 81W0
                                          S/N: PF2BZS7D
                                          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                          I already have a CH341A programmer...
                                          04-07-2025, 07:10 PM
