Help Me Please BIOS HP Laptop 15-dw3027nk (455X7EA)
  • Sardired1
    • Dec 2024
    • 7
    • Morocoo
    Hi Everyone
    Please i have an HP S/N : CND1435705 Model : HP Laptop 15-dw3027nk (455X7EA)
    First it comes with Black screen And the CAPS Button Blinking When i tried to Flash the BIOS Now when i try to turn it does not respond
    i need the Coresponding BIOS File Please
  • shiyab
    • Sep 2023
    • 1483
    • india
    Originally posted by Sardired1
    Hi Everyone
    post backup bios
    • Sardired1
      • Dec 2024
      • 7
      • Morocoo
      thanks for yourreply a really appreciate
      • shiyab
        • Sep 2023
        • 1483
        • india
        [QUOTE=Sardired1;n3538876]thanks for yourreply a really appreciate
        [/Q
        this not backup bios
        • Sardired1
          • Dec 2024
          • 7
          • Morocoo
          Then it's damaged !
          • shiyab
            • Sep 2023
            • 1483
            • india
            Then it's damaged !
            post bord no
            • Sardired1
              • Dec 2024
              • 7
              • Morocoo
              GPT52 LA-K201P Rev:1.0
              2020-09-18
              Made In China
              UG2
              C
              • shiyab
                • Sep 2023
                • 1483
                • india
                hi try
                • Sardired1
                  • Dec 2024
                  • 7
                  • Morocoo
                  Hi sir i really appreciate your reply i got this error while veryfing
                  • Sardired1
                    • Dec 2024
                    • 7
                    • Morocoo
                    Now its erased flashed and verifyed but the Caps button keep blinking
                    • Rebirth
                      • Sep 2022
                      • 50
                      • Myanmar
                      Here is your Bios with various BID numbers, you need to find your exact BID and write that bios
                      • Sardired1
                        • Dec 2024
                        • 7
                        • Morocoo
                        Thank you so much for your reply
                        should I try them one by one ?
                        • Rebirth
                          • Sep 2022
                          • 50
                          • Myanmar
                          If you have HEX Editor, open your old bios and search for BID until you find the same number form my file and write the same number. If you don't have old bios you can try one by one
                          • JoWed
                            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                            by JoWed
                            Hello Community,
                            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                            07-01-2025, 09:32 AM
                          • thxd43
                            Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                            by thxd43
                            Hello, first of all, excuse me, I am using the translator, English is not my native language.
                            I have a Lenovo ideapad 330S - 14IKB laptop.
                            The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                            02-23-2023, 08:37 PM
                          • legendkray
                            BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                            by legendkray
                            I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                            07-05-2025, 09:25 AM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • Loli Popu
                            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                            by Loli Popu
                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                            12-13-2024, 03:28 AM
