Need Bios file Panasonic CF-54EY147TG
  • Tester2009
    • Dec 2020
    • 8
    i need Biosfile for Panasonic Toughbook, mine is corrupt.
    model CF-54EY147TG
    chip 25L12873F
    board 0PB11074CAA
  • Tester2009
    • Dec 2020
    • 8
    serial 9ATCC03005
      • 22279
      Originally posted by Tester2009
      serial 9ATCC03005
      Post your corrupt backups
      • Tester2009
        • Dec 2020
        • 8
        i read with afuwin and then tried unmodified file afuwin.rom to write back. error 43 came up.
        reboot
        then read again. this is afuwin_def.rom
        now laptop has graphic problem and does not start every time. stupid from me.
        i can read / write chip with programmer if needed.
          • 22279
          reboot
          Yes, use your programmer, make a full backup.
          • Tester2009
            • Dec 2020
            • 8
            here is backup read with ch341a and clip. i repeated 4 times and got same result.
            • Tester2009
              • Dec 2020
              • 8
              i tried writing and verifying its okay too.
              can somone repair the dump or is there a clean dump? i would like to install last update offered from panasonic.
              how do the chips work, sold on ebay? why they are selling with hardware and not only dump?
              • Tester2009
                • Dec 2020
                • 8
                is it possible to extract bin from original panasonic update exe file? with starting update and looking in temp i wasnt sucessfull. 7 zip extracts some parts but not usefull in my sight.
                  • 22279
                  Yes with panasonic bios extractor. https://www.badcaps.net/forum/troubl...26#post1622426
                  The bios update then needs further editing with a hex editor to remove a capsule/bios update header
                  Try this one.
                  • Tester2009
                    • Dec 2020
                    • 8
                    It worked for me. Thank you very much.
                      • 22279
                      • to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                        by to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                        I have opened the laptop and identified the main BIOS chip...
                        10-24-2025, 01:35 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • maanee11
                        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                        by maanee11
                        Hello Everyone,
                        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                        In the website, you can only see specs etc.
                        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                        11-08-2025, 04:08 AM
                      • m1ch43lzm
                        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                        by m1ch43lzm
                        Hi everyone
                        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                        There's also an extra OTP Secu.R...
                        09-06-2025, 05:47 PM
                      • Forest79
                        by Forest79
                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                        07-23-2023, 07:39 AM
