Need Bios file Panasonic CF-54EY147TG
  • Tester2009
    • Dec 2020
    • 8
    i need Biosfile for Panasonic Toughbook, mine is corrupt.
    model CF-54EY147TG
    chip 25L12873F
    board 0PB11074CAA
  • Tester2009
    • Dec 2020
    • 8
    serial 9ATCC03005
      • 20674
      Originally posted by Tester2009
      serial 9ATCC03005
      Post your corrupt backups
      • Tester2009
        • Dec 2020
        • 8
        i read with afuwin and then tried unmodified file afuwin.rom to write back. error 43 came up.
        reboot
        then read again. this is afuwin_def.rom
        now laptop has graphic problem and does not start every time. stupid from me.
        i can read / write chip with programmer if needed.
          • 20674
          reboot
          Yes, use your programmer, make a full backup.
          • Tester2009
            • Dec 2020
            • 8
            here is backup read with ch341a and clip. i repeated 4 times and got same result.
            • Tester2009
              • Dec 2020
              • 8
              i tried writing and verifying its okay too.
              can somone repair the dump or is there a clean dump? i would like to install last update offered from panasonic.
              how do the chips work, sold on ebay? why they are selling with hardware and not only dump?
              • Tester2009
                • Dec 2020
                • 8
                is it possible to extract bin from original panasonic update exe file? with starting update and looking in temp i wasnt sucessfull. 7 zip extracts some parts but not usefull in my sight.
                  • 20674
                  Yes with panasonic bios extractor. https://www.badcaps.net/forum/troubl...26#post1622426
                  The bios update then needs further editing with a hex editor to remove a capsule/bios update header
                  Try this one.
                  • Tester2009
                    • Dec 2020
                    • 8
                    It worked for me. Thank you very much.
                      • 20674
                      • Forest79
                        by Forest79
                        07-23-2023, 07:39 AM
                      • maanee11
                        Help to get Lenovo BIOS bin file for Thinkpad T560
                        by maanee11
                        Hello Everyone,
                        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                        05-15-2022, 11:59 AM
                      • Sebastian Codrean
                        BIOS file for ASUS F542UN laptop
                        by Sebastian Codrean
                        Hello to all of you! I need help with a BIOS file.
                        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                        02-20-2025, 10:25 AM
                      • Fr33man
                        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                        by Fr33man
                        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                        *Novo button power on
                        *Disconnected internal battery...
                        09-23-2024, 01:16 PM
                      • iZakre
                        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                        by iZakre
                        Hello everybody!
                        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                        The thing is that I had installed TeamViewer and could log into the computer...
                        02-19-2023, 02:27 PM
