Latitude 3530
  • bondminer009
    • Nov 2023
    • 48
    • Malaysia
    Latitude 3530
    Good Day,
    Still stuck with my laptop - Latitude 3530
    - ST : H3NZLL3
    Laptop current condition : Keyboard on - no picture , and sometime if press D+power button, display color appears, no logo and keep restart with same symptom.
    Tried to replace with New Bios still can't, try to ME clean, the problem can't decompose.
    Need guidance and support for this case, still confuse about file if FIT difference with ME (e.g : ME 16.1, FIT 16.0 , try FIT 16.1 also can't decompose)
    Thank you
    Salam
    Three
  • minhdigital
    • Nov 2022
    • 764
    • Vietnam
    Originally posted by bondminer009
    Good Day,
    - ST : H3NZLL3
    Thank you
    Salam
    Three
    Send to you, try
    • bondminer009
      • Nov 2023
      • 48
      • Malaysia
      Originally posted by minhdigital
      Send to you, try
      Appreciated it brother, Thanks. Tested already - yellow of LED once press the power button
      • MAREBELE
        • Jan 2023
        • 41
        • Indonesia
        Send to you, try
        Hi.
        iam facing the same issue and traying to learn how to do it my self, can i ask how you work arrounf it. are you using a diffrent methord or software to clean the me?
        thanks
        • peste
          • 13395
          • ROMANIA
          Originally posted by MAREBELE
          Hi.
          thanks
          Re: BIOS guides, methods, resources and tools
          2. How to clean ME/TXE region
          Cleaning ME/TXE region is required after replacing the PCH or the SoC. Sometimes the ME region gets corrupted on its own and it also required cleaning.
          Cleaning ME/TXE region consists in replacing the existing ME/TXE region in the BIOS dump by a fresh, non-paired one, retaining the manufacturer's configuration.
          Symptoms when ME region cleaning may be required include:
          • Shutdown after 30 minutes (unrelated cause is using Core i3/i5/i7 with HM70 PCH, cleaning ME region won't help)
          • Slow POST
          • Fans spinning at full speed
          • Intel MEI not working in Device Manager
          • In case of Apple machine, macOS reboots or freezes during boot
          • No POST
          Refer to: https://www.badcaps.net/forum/showthread.php?t=88533 and https://winraid.level1techs.com/t/gu...lization/31277 .
          Do not use use Intel ME/TXE Injector/Easy Clean ME or similar tools: they do not retain the manufacturer's configuration and can cause subsequent problems.
          MS Surface no touchscreen after cleaning ME Firmware: https://www.badcaps.net/forum/showthread.php?t=104153
