LATITUDE 3540(13th gen i5) and latitude 3530(12th gen i5) bios needed ;/
This topic is closed.
Split into 2 separate topics, one for Latitude 3530 and the other for Latitude 3540, use the search feature to find the right topic you need, post your request there.
Attach servise tag number and backup bios file.Last edited by hoaca388; 01-01-2024, 11:47 PM.↵
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
Channel: BIOS Requests ONLY!
by robkomHello
The laptop starts without an image. After resetting the BIOS, it boots correctly. Unfortunately, without an image. On LCD and on an external monitor.
I searched the entire bios forum, unfortunately I did not find a bios for this motherboard.
With other BIOS found here, the laptop either turns on and off or turns on with no display and the keyboard is lit.
Please someone look at the old bios and try to fix it or attach a bios dump to this motherboard.
Laptop:Latitude 7290
Motherboard AZ20 LA-F311P Rev:1.0
ST:BKFBSQ2
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
by macabookHello everyone,
07-24-2025, 02:17 PM -
by Aarush653Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
Worked good before failed flash now won't power at all.
May have been a bad connection.
Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
32mb chip - 25Q256JVEN
Attach Dell Bios Update file v1.14 - original Dell update...-
- Loading...
