ROG ally Z1 Extreme bios ok?
  • ongobongo
    • May 2023
    • 62
    I'm fighting with an rog ally that i bought broken and which will not start. I found that the ec chip was shorting out so i replaced it with a new and empty one, short's gone and values look good. unfortunately, the ec chip doesn't reprogramm itself although - according to experience from others I've checked with - it should rewrite itself. WHen i attach power, both ec-chip and bios get power supply. to dig further i decided to read bios, maybe there is some corruption going on in there. Bios chip is a Winbond 74m25jweiq, neoprogrammer/ch314b identifies it as W25Q256JW and reads it completly.
    Could someone with knowledge do me a favor and check the image if it is fine or if there is something corrupted/suspicious?
    Thanks in advance
    ongo
  • hoaca388
    Badcaps
    • Jan 2022
    • 12421
    Thanks in advance
    ongo
    Serial number ?
    • ongobongo
      • May 2023
      • 62
      R7NVKD00844528D
      • hoaca388
        Badcaps
        • Jan 2022
        • 12421
        R7NVKD00844528D
        Here
        • hayezy09
          • Jan 2023
          Hi mate did flashing the bios solve this issue? I too have changed ex chip, rog ally works off battery power but wont charge was just wandering if up to date bios flash’s the ite chip and solves issue, cheers bud.
          • ongobongo
            • May 2023
            • 62
            No in my case the bios update didn't help at all.
            If you have it working on battery just update the bios normally than all subsystems should get updates if available
            • hayezy09
              • Jan 2023
              Can’t update the bios because when i try to wipe the ally and do a fresh install of everything it asks me to plug in the usb c charger to continue and it doesn’t pick it up so im stuck now, installed windows 11 from pc and copied it to ssd still same thing, looks like a i need the ite chip to be picking up the usbc being plugged in before i can do anything.
              • ongobongo
                • May 2023
                • 62
                And you are sure the port is physically ok? I doubt it is the ec chip, when the ally itself is working. I'd think it's something with the power management circuit, check the area around the intersil chip (if i remember correctyl, it's the ISL9420)
                • ongobongo
                  • May 2023
                  • 62
                  have you tested the port further by attaching USB-devices?
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • chudofermer
                    Asus Ally rc71l bios
                    by chudofermer
                    Hello!
                    Received Asus Ally rc71l with the wrong bios.
                    Have the original package and all serial numbers.
                    Can anyone help me understand what is wrong?
                    Condition:
                    Received with an original box with all serial numbers
                    Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                    Got the flash dump, nothing found on DMI section
                    No Windows key, just key ID on the box
                    What is done:
                    1. Flash the latest bios version with serial numbers...
                    03-05-2025, 05:42 AM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
