Need EC BIOS Lenovo IdeaPad S940-14IIL Model Name 81R1
  • kodox
    • Jul 2017
    • 329
    • Indonesia
    yes, it's an IdeaPad not Yoga
    need EC bios that on U2502, it's 8Mbit IC from MXIC with marking MX25L8006E
    board number:
    LS40IC MB
    18777-1
    448.0HB02.0011
  • peste
    • Dec 2016
    • 13176
    • ROMANIA
    board number:
    LS40IC MB
    18777-1
    448.0HB02.0011
    post the S/N, post the original content of the bios chip.
    • kodox
      • Jul 2017
      • 329
      • Indonesia
      sorry, i thought EC bios not contain S/N, but here it is: R90W8XTS
      fortunately U2502 is defective and a can't read the content out of it, it's detected on programmer as MX25L8006E but error "no chip is detected" when try to read or erase it
      • peste
        • Dec 2016
        • 13176
        • ROMANIA
        try post #3
        https://www.badcaps.net/forum/troubl...se#post1758400
        according to the Lenovo website the Yoga IdeaPad S940-14IIL has the same bios as the IdeaPad S940-14IIL...
        • kodox
          • Jul 2017
          • 329
          • Indonesia
          try post #3
          thank's for the info but, i tried almost all the bios image in this forum and all bios image is for U2501 (main bios) based on boardview & schematic i found here https://www.badcaps.net/forum/troubl...hematic-needed, i flashed & re-flashed the bios i've found before realizing that the EC has it's own chip for it's firmware and all the bios flashed had a same result as the original bios.
          or maybe main bios also contain ec bios, is that what you meant sir? if it does, which region should i extract it from?
          please advice
            • 21439
            What model is your programmer and software version. Why did you try to erase it, it doesn`t make any sense to do that. Did you desolder the chip or use a clip
            • kodox
              • Jul 2017
              • 329
              • Indonesia
              i use RT809F with software version 20240116, i said tried to erase just to make my self clear that the chip is broken or somehow broken that even trying to erase will result same error. i do have another MX25L8006E chip and worked fine using same programmer for the last two years & that software version almost a year and i always desolder the chip and never used a clip to program a bios chip or other rom chip from the begining i purchased RT809F programmer.
              the link you mentioned to try the bios file on post #3, i already did and even trying for yoga S940-IWL model, i flashed almost all 16MByte image i can found to U2501 but the image for U2502 is only 1MByte. i need this 1MByte because all 16MByte bios files i tried had same result as the original 16MByte image that i've manage to read it from U2501 and save it using RT809F programmer and version 20240116 of the software without using a clip (desolder the chip). i also try "fresh" MX25L8006E chip without any data on it (erased it first using RT809F programmer without a clip) replacing the original U2502 that i assumed broken and motherboard behavior changed, not responding to power button press.
              i attached 16MByte original bios that on U2501, in case someone needed it
                • 21439
                Try this. Not sure if it will work or not as nothing to compare with.
                • kodox
                  • Jul 2017
                  • 329
                  • Indonesia
                  thank's i'll try it (finger crossed)
                  • kodox
                    • Jul 2017
                    • 329
                    • Indonesia
                    i think it's an ec bios you gave sir, motherboard behavior changed after flashed to a fresh chip, 80% power rail present except VCORE & VCCGT. tried flashing main bios (again) nothing changed. i think PCH is broken, well that's for another thread to tell about.
                    anyway, file you gave it is working. thank's, you've done amazing work 🍺
                    • jendkkd jeje
                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                      by jendkkd jeje
                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                      10-11-2024, 03:12 PM
                    • joven016
                      Lenovo Ideapad S145 need working bios HELP!!
                      by joven016
                      Problem is blinking power led only
                      i don't know exactly if it's s145-15igm or s145-14igm
                      have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                      Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                      Already tested some of posted bios here
                      S145-14igm - success but invalid serial and not booting on OS
                      S145-15igm - success with serial and some other info in bios but still not booting on OS
                      already tried installing new windows but always booting on bios setup
                      windows installer flash drive detected on...
                      08-21-2025, 10:55 PM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • mximiliandz
                      help bios lenovo ideapad s145-14iil type 81w6
                      by mximiliandz
                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                      06-20-2025, 06:50 AM
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
