Need BIOS for Asus Tuff FX506HCB-HN216W
  • eastcoastcomputing
    • Feb 2023
    • 58
    Hi there,
    I need the bios file for an Asus Tuff FX506HCB-HN216W
    SN: R6NRCX02193323C
    Mobo: DA0NJJMBAG0 Rev G
    MFD: 06/2023
    Thanks!
  • shiyab
    • Sep 2023
    • 1647
    • india
    Originally posted by eastcoastcomputing
    Hi there,
    SN: R6NRCX02193323C
    MFD: 06/2023
    Thanks!
    post backup bios
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
