Prestigio Smartbook 141 C2 Bios file
  • Kodza
    • Jun 2016
    • 194
    • South Africa
    Hello guys I got a Prestigio Smartbook C2 main board Y116A Rev 4.0and I need the main bios file. The laptop came without bios chip so I need a working file for the same laptop. I have tried support for Presitigio but there is no support for bios. Thanks in advance
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    11-08-2025, 04:08 AM
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
