HP Elitebook 845 G11 bios locked
  • orono
    • Jan 2021
    • 7
    • Spain
    Hi, please I need to unlock this bios, it has password.
    SN: 5CG42821HN
    Thank you.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12234
    HP EliteBook 845 14 inch G11 Notebook PC
    CTNumber_6SSXL0B81JI2W0
    Serial_5CG42821HN
    Sku_AE1A7EC#ABE
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPgSguhKjhk8mEn7nWngpDpnpqprqzr4rNrPrbs4.Rn
    BuildId_24WWLUAZ602#SABE#DABE
    • orono
      • Jan 2021
      • 7
      • Spain
      It is not working, computer rebooted 2-3 times and displayed the message:
      The bios has recovered its identity data from the Embedded Controller due to data mismatch
      So still asks for password when entering the bios. Also the CT Number you posted is from the battery, the System Board CT Number is PTLGT00WBJQ0AE​, could it be related?
      Thanks!
      • rex98
        • Feb 2023
        • 1287
        • Mandaue CEBU, Philippines
        Thanks!
        Try at first boot press f10 apply factory defaults and restart.
        • orono
          • Jan 2021
          • 7
          • Spain
          Exact same problem than before, I get a black screen at first boot so F10 does not work. Then it reboots 2 times and displays the message I posted on #3. I have checked CRC32 after flashing to be sure the patched BIOS was written correctly to the chip.
          Thanks!
          • minhdigital
            • Nov 2022
            • 762
            • Vietnam
            Thanks!
            Send to you, try !!
            • orono
              • Jan 2021
              • 7
              • Spain
              Originally posted by minhdigital
              Send to you, try !!
              Same problem than with the 2 previous unlocked BIOS. I begin to think that HP has implemented some additional security measure on G11 series so when it detects a modified BIOS automatically restores from the EC. I can't find another HP G11 thread on the forum so I can't know for sure.
              Thank you!
              • qayyum786
                • Aug 2018
                • 1958
                • INDIA
                Thank you!
                why don't you post EC bios so some one will look under backup dump
                • orono
                  • Jan 2021
                  • 7
                  • Spain
                  I can't risk damaging the laptop, I don't even know where the EC is located on this particular model. And because nobody on this forum has still unlocked a G11, there is no guarantee to have this issue solved even if I disassemble the entire laptop and find the chip to extract the EC content.
                  If there is no alternative I still have to think what I'll do.
                  Nevertheless, I am very grateful for all the help. Thank you all!
                  • orono
                    • Jan 2021
                    • 7
                    • Spain
                    I am wondering if my problem with the BIOS auto recovering its data is related with Sure Start Gen4:
                    Q: What kind of attacks does HP Sure Start Gen4
                    protect against?
                    A: HP Sure Start protects against any unauthorized
                    changes to the BIOS code or
                    BIOS settings, both for the
                    boot time code and the runtime code. These capabilities
                    protect you from a variety of different attacks, including
                    new BIOS attacks that may arise in the future.
                    https://images.enable.hp.com/Web/HPI...A7-2562ENW.pdf
                    I have a BCU dump of my BIOS settings, some of these may be relevant:
                    Sure Start BIOS Settings Protection
                    *Disable
                    Enable
                    Sure Start Secure Boot Keys Protection
                    Disable
                    *Enable
                    Enhanced HP Firmware Runtime Intrusion Prevention and Detection
                    Disable
                    *Enable
                    Sure Start Security Event Boot Notification
                    Time out after 15 seconds
                    *Require Acknowledgment
                    Sure Start Security Event Policy
                    Log Event Only
                    *Log Event and notify user
                    Log Event and power off system
                    SureStart Production Mode
                    Disable
                    *Enable
                    Also this laptop has an AMD processor with these features set on the BIOS:
                    AMD PSP Permanently Update FW Anti Rollback Security Level
                    *Do Nothing
                    On Next Boot
                    AMD PSP FW Anti Rollback Factory Security Level
                    1
                    AMD PSP FW Security Level
                    4
                    AMD PSP FW Anti Rollback Security Level
                    1
                    HP Sure Start Gen6+ is able to recover the entire AMD Secure
                    Processor subsystem using a copy of AMD Secure Processor
                    firmware stored within the HP Endpoint Security Controller isolated
                    non-volatile memory with no additional dependencies.​
                    https://h20195.www2.hp.com/v2/GetDoc...e=4AA7-6645ENW (page 15)
                    "BIOS Settings Protection" is disabled but "Production Mode" is enabled... Any expert can confirm? I attach my complete dump. Thanks!
                    • cobako
                      • May 2015
                      • Belarus
                      Hello, i have dump from EC flash. Can you help whith password removing? s/n 5CG4441G10
                      • shiyab
                        • Sep 2023
                        • 1581
                        • india
                        hi try and feedback
                        • cobako
                          • May 2015
                          • Belarus
                          Originally posted by shiyab
                          hi try and feedback
                          Thanks. It is patched main bios not EC?
                          • shiyab
                            • Sep 2023
                            • 1581
                            • india
                            mani bios not ec
                            • cobako
                              • May 2015
                              • Belarus
                              mani bios not ec
                              Not working. Bios recovered from EC.
                              • shiyab
                                • Sep 2023
                                • 1581
                                • india
                                press ok button
                                • cobako
                                  • May 2015
                                  • Belarus
                                  press ok button
                                  Password still active
                                  • krogs214
                                    • Sep 2017
                                    • 83
                                    • Philippines
                                    Hi can anyone help clear the bios and disable absolute
                                    HP ELITEBOOK 845 G11
                                    SN: 5CG4386WW7
                                    Thanks in advance
                                    • krogs214
                                      • Sep 2017
                                      • 83
                                      • Philippines
                                      Forgot the EC bin here it is
                                      • shiyab
                                        • Sep 2023
                                        • 1581
                                        • india
                                        SN: 5CG4386WW7
                                        Thanks in advance
                                        hi try and feedback flash mani
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • clrscr
                                          Need unlock bios hp elitebook 835 G11
                                          by clrscr
                                          please help me unlock bios password hp elitebook 835 G11
                                          S/N: 5CG50434RD
                                          thanks!...
                                          06-04-2025, 09:38 PM
