Razer RZ09 0484
  • aslasg
    • Jan 2015
    • 3
    • greece
    Razer RZ09 0484
    Hi all, i have an issue(No picture) with my RZ09-04840GH4 Notebook and i need a dump bios for it. I tryed everyting and the only thing left ist this.
    Please for your help.
    I am attaching the Bios File that it has now.
    Tnank you in advance.
    • 22279
    post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    • aslasg
      • Jan 2015
      • 3
      • greece
      I am sorry.
      Here ist the S/N: BY2310N08401536
      Model Nr: RZ09-04840GH4
      • tekno1
        • Jan 2020
        • 7
        • Ukraine
        Hi need dump for RAZER RZ09-0484REH3
        S/N BY2325N21900074
        old bios​
          SMDFlea commented
          Editing a comment
          Thread merged.
      • istvanszasz99
        Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
        by istvanszasz99
        Product Name: Razer Blade 15 (2022)
        Product ID: RZ09-0421
        Motherboard: CH580
        BIOS Versions I work with: 2.02 & 2.06
        Bios File Size: 32,768 KB
        Dear Forum Readers!
        I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
        I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
        The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
        !!! MY RAZER BLADE...
        11-24-2025, 05:52 PM
      • Awdev
        Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
        by Awdev
        S/N is BY2011A72401766
        Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
        MB Model is: DA530-MB
        Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
        10-18-2025, 02:13 AM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • vinaypundith
        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
        by vinaypundith
        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
        So, I'm looking for a BIOS dump for this machine - a 16MB one....
        08-03-2024, 12:32 PM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
