Request bios 677-n960kr00
  • arif3203
    • Feb 2021
    • 55
    • Banyumas
    Hallo Friend Please share bios code board 677-n960kr00,ic bios not detected and bios cant backup.thank you
    • 21700
    Is this what you mean 6-77-N960KR00-D03A .Post the full laptop model number, and type and post the serial number https://www.badcaps.net/forum/troubl...before-posting
    • arif3203
      • Feb 2021
      • 55
      • Banyumas
      Am sorry this serial number unit and type and code board 6-77-N960KR00-D03A
        • 21700
        What model is your programmer,the software version and the bios chip part number
        • arif3203
          • Feb 2021
          • 55
          • Banyumas
          Use RT809f ,Programmer no problem but ic bios is bad,tested with other ic same type detected in my programmer
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
