Bios file for HP Victus 16 / LA-M788P
    • 22283
    Originally posted by fredo
    I tried it and it didn't work, although the device was working, but after updating the BIOS the screen became black
    Flash the bios again and stop it from updating through bios settings or windows update.
    • Kaasis
      • Feb 2021
      • 18
      • Latvia
      Hello.
      Black screen after turning on.
      CapsLock blinks 5 long 3 short
      SN: CND41122N2
      Ori bios bin -
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        Originally posted by Kaasis
        Hello.
        SN: CND41122N2
        Ori bios bin -
        try
        • Kaasis
          • Feb 2021
          • 18
          • Latvia
          Originally posted by volinakis
          try
          Same capslock blinks
            SMDFlea commented
            Editing a comment
            The bios is good. check for loose ram slot pins.
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
