SLEEKBOOK Envy m6-k088ca Bios Dump
  • mohamed.mostafa
    • Sep 2012
    • 40
    • egypt
    hi all .
    i need bios dump for hp sleekbook m6-k088ca . AMD CPU .
    thanks
  • mohamed.mostafa
    • Sep 2012
    • 40
    • egypt
    Re: SLEEKBOOK Envy m6-k088ca Bios Dump
    up ...
    • mohamed.mostafa
      • Sep 2012
      • 40
      • egypt
      la-9851p
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        down load it from hp
        • mohamed.mostafa
          • Sep 2012
          • 40
          • egypt
          i did , but its coded . i tried phoenix tool. it cant read it .
          • khaahk
            • Dec 2013
            • 830
            • Estonia
            Download, execute on another machine, choose option of copy and you get the bin file at desired location.
            • nazrul145
              • Jan 2014
              • 339
              • BD
              I need this motherboard schematic.
              Or what ic is PU101..
              • alas3376
                • Nov 2011
                • 382
                • BENIN
                pu101 is BQ715
                • ndher86
                  • Aug 2016
                  • 40
                  • Indonesia
                  BIOS HP Envy m6-k010dx - VPU11- LA-9851P
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
