asus k43sd rev 2.0 uma bios
  • amyrhmz
    • Jul 2022
    • jjn
    hi , can anyone repair my original bios ?
    asus k43sd rev2.0 uma
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    Post serial number .
    • amyrhmz
      • Jul 2022
      • jjn
      my problem was sb chip , bios file is ok , thanks
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • maciek1221
        Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
        by maciek1221
        Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
        Config:
        Model: Asus G512LV-HN235T
        Platforma: G532LWS rev. 1.3
        CPU: intel i7-10870H
        GPU: nVidia Geforce RTX2060/...
        03-07-2024, 07:54 AM
      • Technodoc
        ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
        by Technodoc
        Asus laptop G614JZ-N3012W Rog Strix with i7
        Mainboard G634J-PMV-VGT
        6050A3441302-MB-A01
        2023-02-10
        Power button works okay....power light goes on
        Red "bottom" leds go on
        Charging led works
        Fans do not spin, capslock key does nothing, screen stays black
        I would like to program the bios again, to rule out a corrupted bios.
        However I run into a size error
        The bios chip is a Winbond 25R256JVEN
        Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
        02-24-2025, 04:46 AM
      • skipron.rm
        ASUS Zephyrus GX701LXS BIOS request
        by skipron.rm
        Hello everyone, trust you're doing well.
        I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
        I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
        However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
        The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
        My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
        Badcaps - Capacitor Search Engine & Electronics Repair Forum
        12-11-2023, 06:12 PM
